Results 1 to 9 of 9
Thread: Lowering My Car
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Lowering My Car
    What and how would any of you recommend on lowering my car. If there is any information like what brand would you say is the best and what do I need.
    What's all I should Purchase:
    Cost of it all: (I have the 18 inch rims on order from OZ they are sick)
    Any help or comments are greatly appreciated.
    OZ
    Also just remembered because of the other thread, are there any replacement lights for the reverse lights?
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: Lowering My Car
    you can get lowering springs(cheapest), coil overs(pretty expensive), bags(I'm guessing ridiculously expensive), or just cut your springs (dirt cheap but extremely extremely extremely not recommended haha)
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Re: Lowering My Car
    do a search. Topic has been beaten to death. I will add my 2 cents: Labor will be the same whether you just get springs (~$250) or spring/shock combo (~$800) or coilovers (~$1000). All the same stuff has to come out and then back in no matter what choice you make. Labor can run $250 - $700 depending where you go!
    Getting just springs - ok if labor is $0 and don't plan on keeping your car long.
    Spring and shock - no adjustability but many don't care and just want to remove fender gap. Running aftermarket wheels with non-oem offsets 'might' have potential rubbing issues.
    CO's - adjustable, highly recommended. I would have gone this route but took a gamble on my oem shocks and lost.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Lowering My Car
    Ok sorry about adding this thread, I should do a search from now on.
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Re: Lowering My Car
    Quote Originally Posted by autoverrückt View Post
    haha, i remember that
    unless you plan on doing the labor yourself, don't bother wasting money on springs. do it right the first time and get coilovers take it from another person who had to learn that the hard (and expensive) way.
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Lowering My Car
    Yeah thanks for the advice I am now going to look at coil overs, I dont like the CO stuff however. I will do all my homework before I make a purchase. Currently looking at KONI coil overs. Thanks for help.
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    Re: Lowering My Car
    love my koni's, but i think given another go i would get stasis street sport. they are basically the same, but stasis has a spacer on the rears. koni's are very low in the rear, so careful bout rubbing.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Nov 09 2006
    08 cooper S, 97 C4S, 95 C4
    Tacoma, WA
    Re: Lowering My Car
    1. Decide what you want to spend.
    2. If you have over 50kmi, chances are your shocks are worn, & lowering springs will blow the shocks soon
    3. If you just purchase a spring/shock non-adjustable combo, find out what it rides like, & the actual lowering it gives. It might be to high, or to low, & you are stuck with it.
    4. Adjustable coil overs give the best range, you can adjust all you want, & change it when you want. You will also get the best performance from this route.
    Just be careful, you can go "cheap" now, then 4-6mo later you will most likely have to replace shocks, or something else, & then pay for the labor twice, end up spending way more then if you just for a mid-range coil over kit in the first place.
