Results 1 to 40 of 52
    Jun 14 2007
    Lafayette, IN
    Question Similarities between 2.8 and 2.7T?
    I've been trying to find detailed engine info between different Audi engines and I'm particularly curious about the V6 line. I have a 2.8 30v and I'm curious how far back and forward this basic engine design has been used. Is the 2.8 12v the same basic engine design all the way up to the current 3.2 or 3.6? Were there any complete redesigns in the last 10 years? In particular, is the 2.7T any relation to any of these?
    My biggest question is this. Could one take turbo manifolds from a 2.7T and associated hardware and bolt it all on to the 2.8 30v and then run custom engine management? In the Nissan SR20 world, it is not so uncommon to turbo the USDM SR20DE with similar turbo parts that come on the JDM SR20DET, albeit with higher compression and therefore more conversative timing and fueling. Why can't I do the same thing with my 2.8? Find the turbo parts off a 2.7T, bolt them on, and then tune my car to run those turbos? Yes, I'd need more than the turbos. Injectors, intercooler(s), plumbing, etc. Similar stuff that comes with the PES G2 kit, just turbos instead of a supercharger.
    This of course depends upon the 2.8 30v and the 2.7T exhaust ports being pretty much identical and the heads/blocks being similar enough for everything to clear.
    Discuss. :)
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Similarities between 2.8 and 2.7T?
    You can use 2.8 heads on 2.7T so the exhaust ports will line up. 12V V6 has the same block as 30V V6 as far as I know. Im not sure how the 3.0 and 3.2 are compared to the 2.8 thou. 3.6 is a VR6 engine so its completely different.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    2.8s are iron and the 3.0s are alloy blocked iirc
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    2.8(30V) and 2.7T heads interchange. The 2.8(30V) crankshaft is the same as the 2.7T's. Transmissions are both "Multibolt" designs, so they'll interchange as well as retain the same mounting points. Both 2.7 and 2.8 can become 3.0L w/ a simple overbore.
    I don't know much about the 3.0 and 3.2, but it's a different breed. The engines changed a lot.
    The 2.7T guys swap to the 2.8(30V) heads to lower compression IIRC. I don't think there's a flow difference.
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    the motor in doestic 240s is a ka motor not an sr motor. The 2.7 block started life as a 2.8 but they thickened the cylinder walls for that massive amount of boost pressure that that the stock s4 puts out. If you want forced induction on the 30 v get the super charger and a southbend stage 3 clutch. a very fun combo and smooth factory like power delivery. The g2 does not come with intercooler nor is it possible to do so. Just bolting on the 2.7 manis is not possible from what I was told (wich doesnt mean squat so check for yourself),but if you couls do it anything beyond 15 pounds might do somthing nasty to your motor due to the comp ratios. Go to scaudi.com ask a guy named 4rings your qustion he is very savy when it comes to the 2.8. good luck.
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Jan 19 2008
    Quote Originally Posted by Sigma 3 View Post
    He never mentioned the 240SX.
    Nissan Sentras and Infiniti G20's came with the SR20DE in the states.
    Apr 14 2008
    a4 avant
    marlboro
    been wondering that same question....because as stated above the heads are interchangeable so everything else should be the same
    now a question id like to ask if any one would know is the vw passat 4motion 30v the same design as the 2.8 or 2.7t
    -vrt-
    Jan 21 2006
    6MT BT Avant Ti
    RI
    What year Passat?
    I have not seen many B5 Passats 4-motion but many B5.5 Passats 4 Motion and those have the 3.0 30 Valve engine.
    This passat type would have a 2.8 30 Valve motor so similar to the 2.7T w/o turbos.
    This passat type has the 3.0 30 Valve engine (aluminum block, different design)
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    One thing about turboing a 2.8 is that the 2.8 block has only 2 bolt mains. Whereas the 2.7 block has 4 bolt mains.
    The 2.8 caps have 4 holes, i believe, and several people have simply drilled and tapped the second set of holes in the block.
    Although i am not sure about the rod strength, i do know that the 2.8 has i higher compression ratio, so if you were looking to turbo the 2.8 you may want to look into an aftermarket rod/piston combination.
    There are several threads around, where people have built 2.8s. You might want to take a look at those and see what they have done.
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Quote Originally Posted by nebone22 View Post
    What year Passat?
    B5.5 Passat has the same 2.8 30v engine like B5. They changed engines in the 02 A4's but not passats. 2.8 engine is used all the way til year 05 4motion or not.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Completely off topic.... The manifold from a Mitsu 4G63 bolts right up to a Honda H23. I did it to my old lude.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Jun 14 2007
    Lafayette, IN
    Smile Re: Similarities between 2.8 and 2.7T?
    Quote Originally Posted by NK2007 View Post
    Lots of great information! Yes, I wasn't talking about the KA24DE. Check out sr20forum.com for info about this motor. I'm so used to the SR in that the bottom end is the same strength in the NA and turbo motors that folks have boosted the NA motor (stock 140hp) to over 400hp with no bottom end upgrades that I forget that not all engines are as overbuilt.
    Where can I find more information or pictures of 2.8, 2.7T engines, external and internal, and maybe comparisons of the stock versus aftermarket rods between the two?
    If these engines are sisters, then I don't understand why people don't take advantage of 2.7T parts for the 2.8. The compression ratio is only 1 point different (10.3:1 vs 9.3:1) which isn't massive. The SR20DE was 9.5:1 and the SR20DET was 8.3:1, so this is the same ballpark. Bolt those turbos on, get an exhaust, maybe 2.7T injectors if the 2.8s are smaller, maybe 2.7T MAF if the 2.8 one doesn't flow enough, and boost that sucker. Junkyard turbo kit. :)
    Yes, I know the PES G2 exists, but I've ridden in a couple of supercharged vehicles before (Grand Prix GTP with pulley, F-150 Lightning) and they just aren't my thing. I love turbos. :)
    Apr 14 2008
    a4 avant
    marlboro
    the passats a 2001 so its a b5 nd i have tried searching for that info with no avail so i appreciate the responses, the wifey mite be getting a nice christmas present
    -vrt-
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    The 3,0 / 3,2L V6 motors are completely different to the 2,4 / 2,7 / 2,8L 30V units.
    Besides the V configuration, they have nothing in common.
    Most obvious change is the loss of 1 valve per cylinder, so 24V.
    The cranks are completely different too, as is the aluminium block.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by djwimbo View Post
    WRONG, guys slap on 2.8 heads for flow, why would they lower CR?
    This is a decent difference. However, 1.8T guys have run up to 1000hp on 2 bolt mains. The S4 middle mains actually have 6 bolts holding them in, overkill IMO but there was no expense spared on that motor
    The 2.8 motor is weak in comparison with its internals. S4s can handle 500awhp on a stock block when some 2.8s have had trouble running too much boost with a S/C
    Quote Originally Posted by Siena View Post
    WHAT? The 30V is a 30V just like the 2.7.... And the block is cast iron just like the 2.7....?
    In conclusion, you might just want to start with an S4 block. find a spare one, throw rods in it, and swap it out with yours down the road.
    Also, you would have to do standalone, but you knew this already
    PM me if you want to brainstorm, I have done some research on this
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Nope. The 2.7 needs a 3.0 crank (added stroke) in addition to an overbore to hit 3.0L.
    -Doug
    Dec 05 2007
    CA LA
    wow never skim a thread cuz things get weired. starts out all audi then randomly nissan engines pop in lol.
    to the OP the 3.2 and the 3.6 are TOTALY diffrent. the 2.8 is a 90 degree V. the 3.2 and the 3.6 are actualy veriants on the VW VR6 engine the are 15 degree if i remember correctly and they only have 1 head
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Quote Originally Posted by GetAwayFromMe View Post
    Hmm that seems correct; I've always thought it had a 3.0 motor.
    Apr 25 2007
    millersville, maryland
    Yeah he's right i have an 02 passat motor in my car right now
    Jun 14 2007
    Lafayette, IN
    References about this? Obviously Audi built up the 2.7T for some reason - I am just out to find out how "weak" the 2.8 is in comparison and just how similar they are. I'd still love to be linked to some pics of each engine if someone has any.
    I've never priced all these parts. Any ideas how much used 2.7T turbos, manifolds, injectors, piping, intercoolers, and all the other associated parts may run me? Maybe it would be more cost effective going for aftermarket parts? I thought maybe someone doing a big turbo upgrade on their S4 or A6 or something would have this stuff laying around and would sell it inexpensively. Or maybe someone who popped their motor and has some of this stuff they are parting out.
    Folks mentioned using the 2.8 heads on the 2.7T because of better flow. What about cams? Do folks place the 2.7T cams in the 2.8 heads? I'm curious about overlap between the turbo and non-turbo cams.
    "Factory-turbo" your 2.8 - has a nice ring to it
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    As noted with most of the above posts, basically the OE 2.8 pistons will self-destruct at 11psi of boost or above. Plenty of info regarding boosting engines on the scaudi.com site; read 4rings' story and you will understand the perils of high boost. The issue is that the high compression cast-pistons crack around the top ring, and the motor self-destructs. The 2.8 motor was just not built for boost, thus can not handle "safely" anything beyond 9psi or so.
    Personally I will replace the bottom end of my 2.8 with a built 2.7t shortblock someday, keeping the 2.8 heads, so that I can up the boost of the PES G2 safely to a much higher figure, perhaps 10-12psi.
    The main reason why some S4 folks change over to the 2.8 heads, is that they are "large port", same size as in the B5 RS4, while the 2.7t's use smaller intake ports.
    My advice if you want a turbo V6 is to sell the A4 for an S4.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    May 23 2005
    Tricities Wa
    Quote Originally Posted by Bendy View Post
    Audi a4 is right, a stock 2.8 is not capable of the boost load that a 2.7 can handle. just adding 9 pounds of boost many of the scd guys started seeing metal shavings in there oil. I told you to check out scaudi.com 4rings bllew his intercooled g1 at only 15 lbs. There is a company in Canada that ttd the 2.8 they sid it cost around 16k. I cant remember the name but the owner is on vortex.
    Jun 14 2007
    Lafayette, IN
    Post Re: Similarities between 2.8 and 2.7T?
    Found the post. Reading it now. Link for others to follow:
    http://scaudi.com/sc/index.php?showtopic=3540
    Jan 21 2006
    6MT BT Avant Ti
    RI
    All the stock parts would be rather cheap as many S4 owners remove all the stock parts and replace them with aftermarket, even manifolds.
    Q7, Q7, F-type manual
    The problem is the pistons and the high cr. Swap in some lower compression pistons and you will be fine.
    Oct 29 2005
    10speed
    San Francisco, CA
    Used stuff will be cheap. K04s would be the way to go. Expect to spend $7k Id say, you have to do standalone and get it tuned. People use the 2.8 cams in both the 2.8 and 2.7 heads because they have a nice grind for making power
    IMO the best setup would be a single turbo 2.8... I would source a 2.7 block (although I would like to see a 2.8 block done) and get standalone. Anything is possible. There are a few (including me) working on single turbo S4 setups right now and I would assume it should just drop in because its essentially the same motor and engine bay
    - Clint
    Jan 21 2006
    6MT BT Avant Ti
    RI
    My buddy is building a 12V 2.8 N/A. It will feature an overbore and other exclusive goodies.
    Definitely one option to consider, you know I am interested. Eagerly awaiting the results. I have to wonder if you could just drop in an S4 harness and ECU at that point?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by audispeed View Post
    lol probably would be worth it at that point. Might be tough to get it to run with the A4 gauges and god knows inspection would be a nightmare but so would standalone lol
    - Clint
    Apr 23 2008
    For those wondering what high boost and a stock 2.8 equals...
    ...this is piston #5 from Tomasz' motor.
    May 23 2005
    Tricities Wa
    Quote Originally Posted by CycloSteve View Post
    Tomas is "4rings" that i was talking about. He is a wealth of info on the 2.8.
    Apr 27 2008
    b5 a4 1.8tqm, e30 m3
    Fairfield county ct!
    the 2.8 and 2.7 crank and rod part numbers are the same. That means that 2.8s have forged cranks and rods. The s4 bore is 80.5mm, if you bore a 2.7 block 60 over it becomes 82.5mm, Which is a 2.8's standard bore size. If you order 82.5mm s4 pistons, the comp ratio will be lower than a 2.8's since they will be meant for the s4, and they will drop right into a 2.8, no drama. Happy boosting
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    ^the 2.7t's rods are not forged. which means, the 2.8's rods are still not forged.
    but everybody already knew that
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Apr 27 2008
    Quote Originally Posted by sean1.8t View Post
    either way, my point is that with both engines having rods of the same part no, the 2.8s rods are no weaker. Thanks for not being a prick about it though.
    Jun 14 2007
    Lafayette, IN
    Question Re: Similarities between 2.8 and 2.7T?
    So it looks like the only important internal to worry about are the pistons. No biggie then. At least the crank can stay in the block. The head and cams are good. What about fueling? Are the MAFs the same? Injectors? Obviously the fuel curves are different which would take at least a piggyback controller.
    So to turbo a 2.8, change the pistons to S4 82.5mm pistons, grab some used turbo manifolds, turbos, an exhaust, intercoolers and associated plumbing, and possibly S4 injectors and MAF, and a piggyback computer. I wonder how different the wiring harnesses are and if an S4 ECU is close to plug n play?
    Oct 29 2005
    10speed
    San Francisco, CA
    Think about all the differences here though,
    1. No Oil squirters in the 2.8
    2. Your pan is not tapped for return lines (might want to get an S4 pan)
    3. You dont have coolant feeds or returns either
    4. The S4 has 2 EGT sensors in the manifolds and 4 02 sensors (does the 2.8 have them also?)
    5. if your pulling the pistons out, slap some rods in there too
    - Clint
    Aug 13 2008
    Indiana
    So say I knew where I could maybe get a supercharged 3.0 A4 with a burnt up piston. Would I be able to get a 2.7t block with crank and pistons and mate it to the rest? I would expect they would be willing to sell it since he now has an 05 S4.
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    I'll take advantage of the resurrection here.
    My main question here is: is the S4 a 4 bolt or 6 bolt main??? I was also under the belief it was a 6 but other guys think otherwise? I searched and came up blank.
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    I was gonna say- In order to calc out to 3.00 L i had to spec the 3L 92.8mm crank as well as 82.5 or 83mm pistons. So to REALLY get 3.00L you have to bore AND stroke.
    Its a shame there isn't a 95 or 100mm crank for them.
    Not to start anything, but that piston was clearly melted not damaged from detonation. I'd wager that with more fuel, those pistons would take quite a bit more of a beating.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Quote Originally Posted by pete@integrated View Post
    yes, but the car was running quite a bit of fuel. pete, you know if your S4 rods will fit in the 2.8? Need a tester?
