Results 1 to 40 of 65
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    Hitting the drag strip this upcoming week end, have a cpl Q's
    I am going to participate in our strip's Sport Compact day... apparently I get as many runs as we can fit in the day, about 40 competitors so far... head to heads in mixed classes but comparing slips at end of the day for prizes and whatnot. Able to do any tuning or match up with certain cars if we want to. Should be fun, a cpl other Euro's, plus a BUNCH of Subaru's and the usual crowd will be out.
    My ride has big wheels. I DOUBT, although I have a cpl requests out, that I will be able to change this fact before this week-end. They're 19" Oettinger wheels and along with their Kumho Ecsta's - 235/35/19 adds up to about 52lbs per wheel. Heeaavvy.
    So, I am not really racing for any competitive reasons... it's just for fun and hopefully a tweak here or there (hence my AFR thread). I doubt I will granny launch it, but I don't want to snap my axles with these steamroller wheels.
    Any tips please?? I have years of autocross experience (in my GLI), but don't have tons of launching-this-car-hard experience. So, tire pressures, launching, shifting timing (I redline at 7k with a GT2876 giant AR)... race gas injected under boost via staged bank of injectors...
    Thanks!,
    Bill.
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Hitting the drag strip this upcoming week end, have a cpl Q's
    Sick rims man and also try to get some 100 octane.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Feb 25 2007
    1998.5 A4 2.0BT
    Thanks for the rims comment, I buy 110 in bulk
    When she hits about 1 psi, a second injector bank shoots 104 for a nice kick in the pants.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    lower you tire pressure to 25 lbs
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Euro-Tuner View Post
    What? He said he did not want to snap an axle and will be running heavy wheels. He should start with the tire presssure high(40psi) and then lower it to increase traction if he needs it. The higher pressure will allow him to spin those wheels much easier and its better to spin the tires then it is to bog and higher tire pressure will help on the top end which means higher trap speeds.
    Feb 25 2007
    1998.5 A4 2.0BT
    Thanks again, I assume some things I just have to figure out for myself, my car keeps building boost right through redline so I always want to keep it going... but get caught sometimes with the slow Tach.
    Not going to do a 3000rpm clutch drop to launch, but we'll see what happens :)
    Jan 25 2006
    A4 2.0T
    MD
    3000???? Try 6000 +
    Feb 25 2007
    1998.5 A4 2.0BT
    Hahahaha, sheeesh, typo! wrong row on the keypad
    hehe.
    Apr 22 2007
    Riverbank, Ca
    Quote Originally Posted by B5Burn View Post
    Slow down there tiger.... You want to show/explain this one?
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by andyrew View Post
    probably extra injectors in the intake mani runners controlled by a stand alone computer.
    Feb 25 2007
    1998.5 A4 2.0BT
    Yes, Don's got it. I have an extra injector in each intake runner, shooting the 104 from a trunk mounted tank.. controller to set when and how much.
    This car was built back when you were just hearing of Neuspeed and TAP (Total Audi Perf)... "easier" ways (but still $$$) to get the power from our motors now, but this works awesome.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    What about the normal injectors; whats the flow of those?
    If you had normal injectors spray required fuel at boost and then extra race fuel, it would just run pig rich so this race gas fuels only at boost? Would regular 93 octane gas on primary injectors still power the car at boost?
    I like the idea behind it. Don't have to drain the tank to put regular fuel in. Do you still have a fuel pressure regulator?
    Cars in europe and other places I believe run a seperate propane tank and can switch between gasoline and propane on the fly so this is the same concept.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 25 2007
    1998.5 A4 2.0BT
    The main injectors are green top, I can't remember what the flow is, the extra injectors are red tops.
    The main injectors shoot 94 full-time, then once boost begins, the extra injectors begin firing the 104 (in ratio to the boost, so not at 100% all the time) simultaneously. My timing and other parameters are all coordinated for the combination of the 94+104 for max power.
    Jul 07 2004
    socal
    Most likely 440cc(green) and 310cc(red).
    You didn't happen to buy this car used? There was a guy on AW that had a car just like this which he bought used, he also owned a stage 3 white A4.
    Feb 25 2007
    1998.5 A4 2.0BT
    Nope, not the same car. This was built by the friend I bought from (well, built by the shops he paid to build it in BC, that is)... drove it so little, which is why I got it with only 30,000kms on the clock.
    I've known this car since it came off the lot.
    There are quite a few SDS systems around. Just not so many built this aggressively.
    Jul 07 2004
    socal
    Any plans to upgrade to a 30r seeing that you are running a 2 liter?
    Apr 22 2007
    Riverbank, Ca
    Trick stuff! Probably a lot of plumbing and custom tuning/work required for that one, but certainly very cool!!
    Andrew
    Feb 25 2007
    1998.5 A4 2.0BT
    Ohhh, absolutely!! I have to change out my GT2876 in a bad way. I have a massive .86 A/R, so, gobs of top end power that just wants to keep going after redline, but now that this car see's more street driving, I want to match the turbo better. She has seen some track time originally, so it was 1 first gear launch and then all high speed boost.
    B.
    Jan 25 2006
    A4 2.0T
    MD
    Any underhood pics or previous dyno / track numbers?
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Wow. So wait, what's the benefit and/or difference of this over meth injection?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Jul 07 2004
    socal
    Quote Originally Posted by sixfiveoh View Post
    Not the same thing. He is using 8 injectors in place of just running 1 set of larger injectors. People did that back when there weren't any high imp injectors larger then 440cc. Not an issue now.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    And you can always have racefuel in the tank.
    Jan 06 2007
    NH
    race fuel is a good idea even if you arent written for it, it will prevent detination.
    Jul 07 2004
    socal
    Running to high of an octane can actually decrease power and you end up with misfires.
    Feb 25 2007
    1998.5 A4 2.0BT
    Quote Originally Posted by Don Supreme View Post
    My motor isn't show-y.. but check the pics Rob took in his thread... plus check his stuff, it's awesome.
    http://www.audizine.com/forum/showth...=228298&page=2
    No dyno numbers in my possession.. it would be amazing if I could get a pull at one of the Minneapolis shops on the HIN week end coming up... no idea there though. The previous owner shared some paper numbers, and some runs he had... but nothing of substance, so, nothing. We'll see what happens after the week end. Just came from my mechanic, new bung installed. Time to tweak!
    B.
    Jul 07 2004
    socal
    Feb 25 2007
    1998.5 A4 2.0BT
    Or work some internetz majic (sorry, I am lazy) and there you go, haha, thanks Mike.
    Just came home from a great rip tonight (don't you love the fall-season temps?), so tomorrow I am going to do some logging, new to me also.. should be 'fun'.
    B.
    Jul 07 2004
    socal
    B.
    Fall season temps? I wish, here in socal it is still hitting 100 during the day and right now at 4:40pm it is 90 degs.
    Feb 25 2007
    1998.5 A4 2.0BT
    It's a crispy 19C / 66F tonight :) Time for more driving.
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    I'm not too big into 19's on B5's but I gotta say those do look sexy. If you were near Chicago I'd lend you a set of 17' 19lb track rims. What clutch do you have to handle those launches?
    Feb 25 2007
    1998.5 A4 2.0BT
    Quote Originally Posted by audi til I die View Post
    Thanks!! and thanks!
    The clutch is not OEM, but the PO forgot what brand is in it... I won't be shitting on it, I don't think.. it is strong and isn't slipping or anything (yet). Haha, may dig into a new SB sooner than later!
    B.
    Feb 25 2007
    1998.5 A4 2.0BT
    Well, that was a blast. However, my tune was way off and being too rich was zapping my boost hard. So.. slow time, but I am feeling positive about doing A LOT better. I barely broke 12psi when I can hit 20's easy. Felt like I had NO boost. Pulled some numbers back and by end of day, this was the best I could do, ok for my first day, I guess, haha.
    My highlight of the day is launching an A4 at 6000rpm slipped the clutch just enough to generate some wheel spin on my fat tires (bumped them to 40 as per Mike's tip).
    I have some in car vid I'll upload soon.
    60: 2.07
    330: 6.25
    ET @ 594: 8.98
    1/8 ET: 9.58
    1/8 MPH: 75.04
    1000' ET: 14.73
    1/4 ET: 14.73
    1/4 MPH: 95.16
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Sounds like you had fun.
    14.7 on a 2876? How rich were you running and why?
    Feb 25 2007
    1998.5 A4 2.0BT
    Got in about 7 runs, tons of fun.
    Well.. with the .86 AR on my turbo, 1st and 2nd are almost stepping stones to the power... not literally, there is good boost after 5k, but this car hits its stride in the top end of 3rd and into 4th (JUST as I am crossing the line). I feel like I could snap the needle if I just kept my foot planted through 5th. Excuses, excuses. Highway driving is a frikking blast in this car. I could feel the car accel slightly when I let off the gas at the end of the run....
    Anyway, after doing some logging last week, I added a little fuel down low based on some readings I had and pushed the AFR a llllittle too rich. Completely zapped the low end and spool up. I didn't have any of my map printouts or a laptop with me, so I roughly pulled the curve down a little and the power started coming back.
    I am positive I could be hitting 105mph+ or so based on some other test runs I have done.
    B.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I don't know much at all about tuning, so I'm not sure what could be done w/o changing the A/R, but that looks like it might be part of the problem.
    Feb 25 2007
    1998.5 A4 2.0BT
    Oh yeah, I just wanted to drag so I could have fun and do some logging... if I could, I would be bolting a GT30somethingorother on by now. There are a handful of turbo's that match my displacement better for the driving I want to do.
    I have been watching the 3071 vs 3076 threads... but just standing on the sidelines.
    On the tuning side, I figured out a whole bunch from my runs, so I have already clawed back a bunch of power.. plus, SDS is awesome with working with me and my numbers.. so, next strip day will just be quicker :)
    Feb 25 2007
    1998.5 A4 2.0BT
    PS, is it just me or is the tach on our car a little slow??
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Mine works fine. At least I can't complain.
    My rev limiter is supposed to be at 6500, but I've gone past it a couple times on accident. The gauge seems to rather accurate when that has happened.
    Established Member Two Rings SouRce4's Avatar
    Dec 02 2006
    B5Burn what kind of rear bumper or lower valence is that? it looks pretty nice
    '99.5 A4 1.8t FrontTrack 5spd
    ST Chipped K03s :: Custom Catback Exhaust :: Bailey DV :: Custom Intake
    Koni Coilovers :: Strut Bar :: 8000k HID's
    Custom Interior :: Custom Dash and Gauges :: 30% Tints
    Blacked Out 360°
    DÜB Wehrmacht / / / Many Audi's and VDubs
    Jul 07 2004
    socal
    Yes. The more power you make and the quicker the engine can rev up while in gear you will notice that the stock tach has a problem keeping up in the lower gears.
    BTW your 1000 ft and 1/4 mile ET are the same.
