Results 1 to 4 of 4
    Veteran Member Four Rings knight007's Avatar
    Mar 10 2004
    SoCAL
    HELP Cam Tensioner Tool stuck!
    I just finished installing a new Cam Tensioner gasket and half moon and also the valve cover gasket. All 4 bolts tightened on the Cam Tensioner then as I was unscrewing the Cam Tensioner tool, the bolt got so loose and felt I can remove it BUT no deal. The tool is now STUCK! Anyone in here have an idea of what happened and how to remove it?
    Front Wheel Drive REVO 71r Elim
    Oettinger
    SSR J-Spec
    I still have HONDA blood in my veins.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: HELP Cam Tensioner Tool stuck!
    Can you pull the bolt for the tensioner tool completely out? The chain may be wedged against the nylon top piece. Have you tried recompressing it and moving the chain slightly. Then taking the tool out again?
    Just don't put the valve cover on with the tool in place. The valve cover gets caught and then you bitch and moan...
    -Doug
    Mar 10 2004
    SoCAL
    The bolt is whats not coming off. Even though its unscrewed and loose. The chain is not caught on the tool itself.
    Oettinger
    SSR J-Spec
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by knight007 View Post
    Sounds like you might have to pull the tensioner out of the car and see why the bolt is not coming out of the bottom of the tensioner.
    -Doug
