Results 1 to 11 of 11
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    trouble installing apexi TT
    so here i am confused as fuck lol. ive searched and searched everything. read all the greddy tt III install, chads ''guide'' and kitchs ''post''.
    i have everything down execpt my ''target wires''
    Look up to the left of the steering column. There are two harnesses encased in black nylon webbing. The one closest to you is the one you need.
    Slit it open w/ a razor blade. You need the big BLACK wire, one of the two RED wires, & the tiny REDw/BLACK wire.
    so the nylon webbing that i opened had. the big black wire, the small redw/black wire and like FOUR red wires all the roughly the same size! how do i know which one to T-tap???
    can anyone help or clarify what im doing?
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Senior Member Three Rings kjr7888's Avatar
    Nov 23 2006
    NH
    Re: trouble installing apexi TT
    i followed this one and it worked perfectly... http://www.audiworld.com/tech/elec89.html
    i installed the apexi but this diy if for a greddy but its all the same
    Dec 05 2007
    If the install is similar to the Greddy, you don't need to go anywhere near the steering wheel. I had a person install it for me, but wish I did it myself as he installed it incorrectly. So, I went to the DIY write up to correct it and the write up is exactly on point (pictures help a lot). Mine is mounted right by the fuse panel via industrial strength velcro.
    Edit: I just noticed what you mean by your inquiry. Here is a DIY write up for the Apexi TT, but you really do not need to do all of that. The write up I first placed a link to is very simple and straight foward.
    Last edited by Seerlah; 09-07-2008 at 05:46 PM. Reason: added link for Apexi DIY write up
    Aug 07 2008
    White Rock
    ya maybe ill just follow only the greddy cuz on the greddy install page it has two other links. maybe those are just differant way to do it? thanks
    Dec 05 2007
    The Greddy Install (off website) is rather confusing. The write up above is what you should try. Works for mine. I editted (added) a link for the Apexi TT install, but that too seemed rather complicated (but I am sure is not). Just use this one and chimme back if you have any difficulties.
    Aug 07 2008
    White Rock
    GREDDY INSTALL IS SOOOOO EASY!
    so stolked now im ready for my ''badass'' GIAC file coming next week. not like any other giac :)
    Dec 05 2007
    Quote Originally Posted by TheWrightAudi. View Post
    Are you getting a custom file?
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    My turbo timer = me waiting for my car to cool down if Ive been beating on it.
    Cost = Free. ninety free
    Installation difficulty = 2ez
    I think turbo timers are a gimic in my opinon you can drive normal for a couple minutes before you get home, or let your car idle for a few mins
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Dec 05 2007
    I just got mine because I drive rather spirited and hated sitting in my car for 1-2 min before shutting off my engine. Now I can drive to the destination and hop out with no worries or waiting.
    Say one was in a hurry somewhere and had to hop out the car at arrival immediately (say wife was delivering offspring). While that adrenalin was pumping there would be no issue of having to wait for proper cool down of your turbo.
    I did find the TT pointless at first (before I got one). But now I adore not having to sit in my car (at destination) or staying out of boost couple minutes before arrival.
    Aug 07 2008
    White Rock
    custom file from wicked motorsports :)
    Aug 07 2008
    White Rock
    yea if you have the patience to sit in your car for a few min then go for it. but when you hop out your ride and lock your car and walk away with your keys in your hand and everyone is like WTF why is your car running then it kills itself... its a dope feeling ya'll
    lol
