Results 1 to 29 of 29
    Nov 12 2007
    2000 S4
    Boston, MA
    Stock Boost Levels New AWE Gauge
    I just installed a new AWE vent gauge.
    I want to check to make sure my levels are ok:
    Startup/Idle 15-16 vac
    Warm Idle 16-17 vac
    2k RPM cruise 19-20 vac
    Boost spike 7 hold 5.
    Are these good?
    Car has been running outstanding so I just want to check.
    Thanks
    2000 S4 6sp|710N|APR Snub Mount|AWE Boost Gauge|AWE DTS|RS4 Grill|RS4 Door Triggers|OEM Aluminium Trim|Samco TBB|Vibrant Exhaust|
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Stock Boost Levels New AWE Gauge
    your vacuum reads a tad low especially on an un-modified S4.... typical vacuum levels on stock intake setup are around 19-21... 17-18 cold.... sounds like you could have a leak somewhere, hows your idle? does it sit perfectly still at 800 ?
    Nov 12 2007
    2000 S4
    Boston, MA
    yes perfect at 800
    Senior Member Three Rings team_soy's Avatar
    Apr 30 2008
    florida
    +1
    check for leaks..i have a horrible misfire(in process to get fixed) and i pull 20-21 at idle
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by JWMGT90 View Post
    yes perfect at 800
    okay, well i mean it can vary, do you have the AC on?
    AC on with those numbers are normal and clutch in.... turn off everything (AC/car in neutral) then whats it read?
    Nov 12 2007
    2000 S4
    Boston, MA
    holds steady between 7-9 in neutral idle
    What should the numbers be? I try searching but everybody has diffrent answers.
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    When the car is idle it should be at 18-20 in. Hg and max boost you should be getting is 10 psi for a stock car.
    Oh yeah and turn the A/C off if it was on... You will get a little difference with the A/C on but not that big. You probably have a boost leak somewhere.
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Nov 12 2007
    2000 S4
    Boston, MA
    Quote Originally Posted by Videlov View Post
    Would a boost leak affect the Hg readings?
    Oct 31 2005
    Ashburn
    Yes, Do you have a boost leak tester? If not try and see who is near you that might be able to help you out.
    - Instagram: @Sinister_rs5-
    Nov 12 2007
    2000 S4
    Boston, MA
    Yes I do have one I will test it.
    What sould the stock readings be so I know?
    From what I read it should be
    18-21 Hg
    9-11 Boost?
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    18-21 Hg
    9-11 Boost?
    Yes sir
    Jun 14 2007
    2000 S4
    Connecticut
    make sure you only pressure test to 15 ish PSI. dont put more than that in the system, remove the oil cap! and cap off the PCV, just follow AWE's instructions :)
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    You should indeed do a boost leak test, but I wouldn't be surprised at all if you have a bad EGT looking at your boost #'s. No check engine light and limits your boost to 5-7 PSI instead of the normal 8-10 PSI (limp mode).
    I got my EGT replaced after a scan showed it as a code and the car pulls much harder, nicer, smoother and does it everytime.
    The reason I mention it is because I thought my car was totally fine, but then found out it was only logging 6.5 PSI....wouldn't hurt to check for codes and rule out the EGT's as culprits...or whatever else might be there if anything.
    Oh, and ensure that all your boost gauge connections are tight and unkinked.
    Good luck.
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Elevation also plays a large factor in this. Warm idle here in Montana is 15-16 inHg while back in Virginia it is around 19-20 inHg.
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Nov 12 2007
    2000 S4
    Boston, MA
    Quote Originally Posted by RuS4ty View Post
    What do you boost at?
    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    Warm Idle 16-17 vac
    I get the same readings on my AWE gauge.
    :: APR V5 :: GIAC Tip Chip :: AWE Boost Guage :: Apikol Rear Diff Mount :: 710N's ::
    Nov 12 2007
    2000 S4
    Boston, MA
    Quote Originally Posted by KryptoniK01 View Post
    Nov 27 2006
    B5 S4
    Vancouver BC
    Stock - about 8 psi
    93oct - spike 17, hold 14-15
    Jul 01 2008
    Stock - about 8 psi
    Note that he is not stock.
    Mine spikes at 20 psi and holds steady at about 17...
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Nov 12 2007
    2000 S4
    Boston, MA
    Does this sound like soft limp mode? Throwing a code with NO CEL?
    I get up to 7psi it drops right to 5 and just stay's right on that number without any fluctuation in the needle at all?
    It seems like the 5 is ECU regulated to me I am just wondering if this is what happens? Thanks
    Mar 01 2008
    Toronto, ON, Canada
    I would guess soft, or even hard limp mode due to a code.
    My stupid EGT caused my limp mode for 6+ months and never gave me code without VAG'ing it, so get yours hooked up and rule that out, wouldn't be surprised to see an EGT there or something else.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    I dont think realistically you'll ever see 10psi of boost. I think that was some number concocted by Motor trend or whatever mag originally tested the car. I saw 8 all day stock on my VDO gauge and the car was in great shape. I just dont think 10 is realistic. I dont know about your Hg readings but they seem a bit low. By low i mean i hit areoun 24Hg when coasting on the street.
    Andy
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Jun 24 2008
    Thread resurrection!
    I also recently put in an AWE gauge. My 2000 S4 (Tip) spikes at about 6.5psi and then settles to 5psi flat. Vacuum at warm idle is 20-22Hg. When cruising around off the gas, vacuum is 25-26Hg. The car runs strong, boost comes fast, and there are absolutely no odd sounds that would indicate bad DVs or anything. I just can't imagine the car being in "limp" mode, and still running this well. I don't have a VAG-COM, so I can't scan. I guess I should get one. (yeah yeah, I know. How dare I even post without owning a VAG-COM)
    Note: I've never driven an S that's in "limp." For all I know, I could be in limp right now!
    Is my EGT suspect like above? I mean, I've heard 7-9 is perfectly normal, so I'm not miles off. I suppose I need to do a pressure test, but my vacuum readings are absolutely picture perfect, so I figured I was good to go...?
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Quote Originally Posted by GunSupplier View Post
    Yea dude, ur vac levels are fine, idle should be 20mmHg.....sounds like a small ride/tear.....easiest hoses to check first are TBB and Fhose, im guessing a SMALL tear in the TBB
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    tiptronics dont have F hoses.
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    bad EGTs possibly...
    B7 RS4...mmmm.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Yo wtf? All I have is a turbo-back catless exhaust setup, and I max 10psi and hold 10. No chip.
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by 00s4slvr View Post
    Damn, did not know that.....
    MKIV BPM R32 (DD)
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    I just installed mine...01.5 6 spd
    I live in salt lake so elevation is around 4300
    My vaccum @ idle went to 15hg, boost in 1st-3rd came up slow and maxed around 9lbs. In 5th-6th boost climbs quickly and maxes around 14-15lbs(I guess my car is chipped, I've only had it for 4 months and I didn't get to talk to the original owner so I wasn't able to get all the details on it)
    Based on what I've read that is not normal for a chipped ecu so I should vag and boost leak test now right gents???
    TIA!!
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
