Results 1 to 15 of 15
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Lower Radiator Hose
    I just put the lower radiator hose sensor in the new hose and it is pretty lose. Is there suppose to be a rubber gromet, or seal that should be in the sensor housing?
    Thanks in advance
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Lower Radiator Hose
    there should be a o-ring.
    Mar 04 2004
    Alaska
    The sensor is hitting the pep cock in the hose. Did audi change the sensor from 02?
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Oct 29 2005
    10speed
    San Francisco, CA
    theres an o-ring on the sensor and then a plastic clip that holds it in place
    - Clint
    Mar 04 2004
    Alaska
    We did that but the sensor still seems really lose. Is this normal?
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Mar 04 2004
    Alaska
    Anyone, I am trying to get this up and running today.
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Nikon44 View Post
    Sean
    No that is not normal. If you are sure you have the "O" ring installed then your problem is most likely that you have not completely seated the sensor. Pull it out and put a little Vaseline or similar on the "O" ring. You may have to twist it a little to get it to seat all the way. If you start the car with the sensor loose the sensor will blow out and you will puke out all your coolant as soon as you build any pressure in the system.
    Good luck!
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    keep fidgeting with the sensor, o-ring, and clip until the sensor is properly seated. I remember doing this and I left the sensor half on loosely and all my coolant drained out over night. definitely make sure its on correctly.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Mar 04 2004
    Alaska
    Anyone know if they changed the sensor housing since 02, my parts guy brought his truck by and we put 2 brand new o-rings on and it seats snug like it should.
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Dec 28 2006
    Western Maryland
    Sean
    Looks like the same hose is used from '02 to '05. Clicky click
    Dec 28 2006
    Western Maryland
    Any chance you have the wrong sensor and you are trying to put a G62 sensor in the lower hose?
    G62 sensor looks like this:
    Aug 16 2004
    SE PA
    should be a black sensor for the bottom hose. simular to the one pictured above.
    Mar 04 2004
    Alaska
    I am putting in the same sensor that came out of my old hose. It looks like the ones pictured but has a grey plug housing.
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Dec 28 2006
    Western Maryland
    Sean
    Then the only thing I can suggest is to make sure it is seated all the way into the hose. I am guessing that you just haven't seated it all the way.
    Again, good luck!
    Dec 28 2006
    Western Maryland
    I assume you still have the old hose. Put the sensor in the old hose and note the insertion depth. Then compare it to the insertion depth in the new hose.
