Results 1 to 18 of 18
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    How to turn two hours into six...
    Decided to replace my cracked ATP exhaust manifold yesterday, what should have taken two hours turned into a six friggen hour job.
    Friggen ARP bolt that holds the turbo to the exhaust manifold bound up and the only way to get it out was to break it (used PB blaster, heat and cold).
    So this meant that I had to remove the whole turbo to extract ther broken stud.
    Did not help that it was well over 100 degree either...in the end however, car is all back togheter and running perfectly.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: How to turn two hours into six...
    I ended up snapping a head stud both times I took the mani off the head to replace due to a crack. They were easy to unscrew from the head though with a pair of stud pliers so i got lucky, then less than $1 for a new stud from Napa and I was good to go.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Buncha motorcycles
    Memphis, TN
    did you have the old ATP design? what did you replace it with?
    APR Stage 2/AWE Intake
    Apr 24 2005
    E55 AMG, CTS-V
    I had the old design then it got replaced with another old design and I just took it off the last time and am getting a new design mani whichi will sell with my gtrs kit when it finally comes. Only been waiting 3 weeks on ATP as of now, but hey what is new with them.
    Pretty sure Greg had the old design as well.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    That sounds like something that would've taken me about a week.
    Suggested Podi install time according to a4mods: 1 hour (no experience necessary)
    My Podi install time: 4 days until *working* completion
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Greg did you mean ARP bolt? We need to get that setup off your car soon and throw a BAT on.
    Apr 12 2007
    Milwaukee
    since my first manifold job, i keep a steady supply of nickel anti seize for every bolt i install.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Warranty replacement from ATP...
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    got to hate when something you know takes little time, and something stupid like that happens to make it take 5 times as long.
    comes with wrenching though.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    yeah. Thats a horrible feeling.. but a greater feeling of relief when you get it done
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    the bolts on my setup brake every time i touch them. you problem sounds all to similar with haveing to get the stud out.
    on the good side aleast it is fixed and working.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I can fix anything...
    105 degrees is way to hot to work on a car though
    Sep 16 2005
    agreed! Sucks when your cooked.. and then you start touching hot parts of cars.
    -Karl
    USP CLUB MEMBER #8
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by 400HPA4 View Post
    Amen to that. It was 75-80degF here yesterday but 99% humidity and I was dying just swapping out a fuel pump. My shirt was completely soaked through after a few minutes.
    At least you got it all back together and working. Sometimes things don't go as smoothly as anticipated. However, its all about the problem is handled to overcome the issues at hand. Great job!
    -Doug
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Thanks for the tip, Greg, but I already know how to turn 2 hours of work into 6
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I've been bleeding my brakes,mc,abs,clutch salve for 8hrs, think my MC is done. I know how you feel...
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by WiZZLa View Post
    good to know... was it an electronic or normal analog gauge? I will update the time (not to 4 days, but to more time)
    i can get one in very quickly, but I've had the car apart so many times I know what tools to grab and how to dis-assemble everything
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Jul 07 2004
    socal
    Quote Originally Posted by Redgoat View Post
    What is even worse is that plus being pressed for time trying to get something fixed while at the track so you can make another run or just get the car home.
