Results 1 to 11 of 11
Thread: piping size
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    piping size
    i have the eurocode intercooler kit but i am installing a bigger front mount and i need to know the diameter of the eurocode piping for their intercooler kit.
    i need two know so that i know what size couplers to get.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Jan 25 2006
    A4 2.0T
    MD
    Re: piping size
    You might want bigger piping too. Especially for the power you are looking to make.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: piping size
    2"
    Blake, from my experience, you may want to not use that piping...
    I had the 2" piping from Eurocode and added a bad ass Garrett high density bar and plate intercooler...
    It was a stellar setup and very efficient, however I sold it and went for the ER Competition setup and there is no comparison on how much better everything fits.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: piping size
    What Sean and Greg said... The piping is probably going to be your bottle-neck.
    -Doug
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: piping size
    I have read that the size of the turbo outlet is the required size of intercooler piping for a good flowing system but you can increase the cold side piping .25, I know that alot of people use 2.25 or 2.5 on new intercoolers but I believe that 2" will work just as good unless your turbo has a larger outlet and then requires a larger diameter pipe to accomadate the flow.
    With a larger pipe it allows more flow and a venturi effect where the charge air can expand and cool some, but then velocity is lost and at higher rpm the car cannot feed itself good enough and power will be lost. An intercooler pipe shouldnt be larger than the turbo outlet on the turbo side and should be slightly smaller than the throttle body on the intake side. This will keep pressure drop to a minimal and velocity high besides using large piping will just bottle neck at the throttle body and intake unless you are using a larger throttle body and upgraded intake manifold.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: piping size
    If it is 2" on both sides you might want to have a shop make a cold side that is slightly larger.
    Apr 24 2005
    E55 AMG, CTS-V
    Re: piping size
    yes the ecode piping is 2" all the way then flares to like 2.5 at the throttle body in last 1" of pipe.
    I had a 2.5" pipe made to transition from the 2" on my intake side.
    ~David~
    CTS-V 9.6@148
    Apr 06 2007
    Re: piping size
    this piping is only temporary becuase i will need to change it once i get my new turbo setup. :)
    visit,
    Apr 06 2007
    Re: piping size
    Can You Also Maybe Tell Me How Big That Eurocode Intercooler Is From The End Of One Outlet To The End Of The Other Outler.
    visit,
    Jan 25 2006
    A4 2.0T
    MD
    Re: piping size
    Quote Originally Posted by A4 TSCHUSS View Post
    I would think the loss of velocity would be a bigger issue @ low rpm.
    Apr 24 2005
    E55 AMG, CTS-V
    Re: piping size
    Quote Originally Posted by 102487thedude View Post
    I dont have that intercooler anymore and I forget. Think it was 26" from end to end though.
    ~David~
    CTS-V 9.6@148
