Results 1 to 6 of 6
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    AVIC d3 install questions
    I am installing the avic d3 into my 2000 s4. I bought the powered antennae adapter, harness adapter, and dash kit. Do I need a cage for mounting it or will it mount to the stock cage? Also how do you do the video bypass so it plays while driving instead of only when the ebrake or whatever is on? ANy help would be great or pointing me in the right direction.
    Apr 27 2008
    Wittering, england
    Re: AVIC d3 install questions
    If I remember right you can just connect the cable that goes to the e-brake to a common earth, should work all the time then.
    Audi S4. Noggy Blue. MRC remap. FK Coilovers. 18" Compomotive MO's. Vredestein Ultracs. Labree downpipes. Vibrant cat-back. Carbon goodies. Cayenne BBK. Hotchkis ARBs. Dietrich RS4 front end. Recaro Pole positions. R8 steering wheel.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    do a search with my user name and avic.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    avic411.com
    -Luis
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    avic411.com has a sticky for the bypass, VERY easy...also, when my d3 was installed they used a cage, so im almost positive you need one.
    Aug 19 2008
    Longmont, CO
    The dash kit crutchfield and installer.com are sending out does not require a cage. The part number is 99-9105. To by-pass the e-brake thing, move the mute wire on the harness into the empty slot directly above it. Then connect the wire to ground. Of course, that is illegal to do. :)
