Originally Posted by
cowens8
Any1 have any idea what's going on with my car though?
Well, the Cruise Control function uses the Cruise Switch on the steering column, to send commands to the engine ECU via the Steering Column Control Module. The SCCM, outputs cruise control commands as message data packets on the power train CAN buss, and the functional cruise control is realized directly in the engine ECU as an Electronic Throttle Control mode.
If you have a VCDS/VAG-COM, you should scan the ECU for fault codes, and also scan the SCCM for fault codes related to CAN comms, and or viewing measuring blocks in the SCCM showing the CC switch states (1=ON, 0=OFF) while operating the switches, etc.
Based on the described coexisting symptoms of higher than normal engine braking on trailing throttle, and the glitchy then no-op CC, I suspect that there is a mechanical or electrical problem with the throttle body/electric throttle drive motor/mechanism. Usually, a fault with the EPC or Electric Power Control/e-Gas system would turn on the EPC fault warning light, but depending on the nature of the problem specifically, may not be monitored by the ECU such that the fault is recognized by the ECU in certain cases.
However, regardless of the background theory explained above, speculation is not helpful. A scan for fault codes is needed to evaluate what may be the problem here.
