Results 1 to 4 of 4
    Veteran Member Three Rings infinitigor's Avatar
    Jul 17 2008
    02' b6 1.8t
    DO i need my 65k service?
    So i have an 02 1.8t and audi just sent me a service reminder.
    I recently got an oil change about 1k mile ago, and replaced all four of my coils b.c one blew. I don't know where my manual is, so I was wondering if i really need to get this service done and if anything bad would happen to my car. I also didn't get my timing belt checked yet.
    If you guys highly recommend getting service done, should i get it done at audi? or vw or simply take it to my mechanic and tell him what needs to be done.
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Re: DO i need my 65k service?
    Timing belt and water pump job should be done around there. I just shreaded my water pump at 75K.
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    I'll suggest that you take a look at this schedule and see waht you havent done...
    http://www.bentleypublishers.com/ima...ance.sched.pdf
    However they did change the intervals for the timing belt starting 2004 i think....
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Jul 17 2008
    02' b6 1.8t
    thx!
