Results 1 to 23 of 23
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    My Audi is teh brokeded....Accelerator Pedal Position issues...HALP!!!
    So I'm in the middle of this tropical storm, right? Its raining heavy, 50mph winds, dark, all the good stuff. To make matters worse, I'm in the middle of fucksville. I'm at my girlfriends dorm which is an hour an a half away from my residence (aka no tools).
    So, I'm coming home from the mall. Just bought a sweet pair of new kicks (see image here). Halfway home, my car seems to buck and stop moving when I press the gas. I figure oh a charge pipe blew off, not really a big deal (still sucks though based on the circumstances). So I pull over and realize, wait the car is idling. So this startles me, so I try to accelerate when I realize the gas pedal doesn't work. Great! So next step is to check for codes, I pull the normals and then P1639. I also realize that my EPC light is on with the car being on. Call up my homo lover AMC, he checks it for me to verify its an Accelerator Pedal Position Sensor. So I gain this knowledge. So this is what I do.
    - Check connections at TB and tap it with my hand to see if it could be a sensor going out
    - Unplug my ECU and plug it back in
    - Check for a fuse for this sensor on the fuse panel (found none to my dismay)
    - Clear the codes and try to start the car
    - Tap/lightly kick the top part of my pedal where the sensor is
    Well, the last part worked....kinda. I tap/kick the sensor and it revs up, so I try to put the car into gear and it stops. Over and over again. As soon as I go to put it into gear. Come to realize, the Accelerator doesnt work AT ALL when the clutch is in, period. But it intermittently works when the clutch isn't in. So I baby it to my girlfriends dorm in 2nd gear (shut off car, put in 2nd and started in 2nd). When I'm about to be at the dorm, I realize that when I got WOT, it doesn't go. Which is probably related to a fucked up sensor, but I just want to mention it. I punch it, the car stays in vacuum at about 16. Oh that sucks.
    Well I've narrowed it down to the pedal position sensor, which in 99.9% sure it is. But I want to ideas or anything from anyone else to see what people think. I've looked around searching and people have had this issue, but it seems like their car was driveable at least. Mine pretty much isnt.
    Thanks son!
    Sep 27 2007
    hate on me <3
    Re: My Audi is teh brokeded....Accelerator Pedal Position issues...HALP!!!
    EDIT: I just realized a lot of people had this same issue when going through car washes and moisture possibly getting into the ECU box and then it drying out and it being fine. Hmmm.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Nice shoes Tony Hawk.
    Stage 3+ RS6's
    Sep 27 2007
    hate on me <3
    lol ive been skateboarding/snowboarding for like 10 years.
    thank you for helping with my issue derek. before this happened i actually thought of you, no homo. there was a store next to the mall called DEB, some girlie gay store, kind of like you. lol j/k
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    ooooo low blow!
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Dec 11 2006
    Boston
    Quote Originally Posted by BurnAll4S4 View Post
    You are such a hipster! Nice to know I am on your mind. I thought you solved your issue (see post #2)? So I figured we could go on to bashing one another and getting this sucker locked up!!
    Stage 3+ RS6's
    Sep 27 2007
    hate on me <3
    <3
    Feb 17 2004
    Sterling, VA
    Are you driving around with no cover on your ECU compartment?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Quote Originally Posted by Daft View Post
    Of coarse, remember? He is stripped, gutted, and lightweight..
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    I've got a brand new S4 electronic pedal, never fitted, was supplied in error for a client, with a 2,8 30V.
    But being RHD, may be different to yours.
    Sep 27 2007
    hate on me <3
    no its just not bolted on, its there
    Sep 27 2007
    hate on me <3
    update: so i keep getting the accelerator position too high. i tried to do the idle and tpa relearn, but that didnt seem to work, i get the same code with the car on, off, it doesnt matter.
    now for the weird part. if i let out the clutch, it revs up to redline (without me pressing gas), and i was getting a brake switch code, so i check the switch and the sensor was off, so i adjusted the switch on the brake. now when i press the brake, it revs up without me pressing the gas. if i unplug the clutch and brake, it revs up without me pressing the gas.
    im still stuck in my girlfriends dorm parking lot, im about to call a tow truck but im trying to get anyinsight to this.
    imma try the idle relearn now that the brake switch is adjusted correctly, but i have a feeling it wont change anything. oh and its sunny and warm right now and its drying up and nothing seem to have changed with that either.
    Sep 27 2007
    hate on me <3
    VAG-COM Version: Release 409.1-US
    3 Faults Found:
    18042 - Accelerator Position Sensor 2 (G185): Signal too High
    P1634 - 35-00 - -
    18058 - Shareware Version. To Decode all DTCs
    P1650 - 35-00 - Please Register/Activate
    16501 - Shareware Version. To Decode all DTCs
    P0117 - 35-00 - Please Register/Activate
    Oct 29 2005
    10speed
    San Francisco, CA
    get the full version lol, especially if you have a car that nearly runs 10 second 1/4s
    - Clint
    Sep 27 2007
    hate on me <3
    yea i will, but any ideas? im really stuck here, kinda sucks.
    Sep 27 2007
    hate on me <3
    so with this new information, i need some help possibly. since im running out of ideas before i have to get it towed. can anyone send me the wiring diagrams for the clutch, brake, and throttle pedal? i think it could be because of a shorted wire with the funky brake problem and revving up. thanks in advance.
    Jan 25 2006
    A4 2.0T
    MD
    probably need a new throttle body.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Purple Pigeons FTW!
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    Feb 07 2007
    Dover, DE
    Sep 27 2007
    hate on me <3
    03spec, thanks.
    oh and car is getting towed home now. ill update once i get it home and take a gander.
    Sep 27 2007
    hate on me <3
    after swapping ecus, swapping gas pedals, a million throttle adaptations. i figured it all out. moisture was the issue. found where i was leaking water too, around the bottom of the ecu box where the gasket goes. nothing some rtv couldnt fix. all is well :-D
    oh and a 2000 s4 gas pedal and a 2001.5+ s4 gas pedal are the same. the plug is in a different spot but both work. just to let people know.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    yay i wonder which nutt swinging buddy helped?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
