Results 1 to 17 of 17
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    How bad? (get in car-boost-turn off)
    I know that there has been a thread on this and ive read it a couple times. I was just wondering what are the lasting effects/initial effects of starting the car, boosting around 8psi right away, then coming to a stop 5 minutes later and turning the car off? What harm is done?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 01 2007
    Irvine
    Re: How bad? (get in car-boost-turn off)
    Not sure exactly what problems you'll have by going immediately into boost, but by shutting off too fast you don't give the turbo enough time to cool down. Oil still remaining in the turbo may cook... but from what i've heard, this is less of a problem with better oil. In general you don't want to push a car until it's warmed up.
    8 PSI isn't too horrible, but short drives like that may be a recipe for sludge issues down the line.
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    You are not giving the oil the proper amount of time to warm up so the turbo will not be getting adequate lubrication.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by ILoveT View Post
    You dont need the oil temps up, coolant temps are way more important. When the coolant temp is low the car runs in a "rich" tune.
    When I run my car at the drag strip my oil temp gauge never even moves before I make a run, but I will not run my car unless my coolant temp gauge is straight up.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Open loop...
    And I still would be scared to run my car if my oil temps weren't up. Yikes!
    Jul 07 2004
    socal
    Open loop...
    Why, what do you consider to be temps for running your car?
    Your gauge reads 150 at its lowest reading, so even though the gauge hasn't moved your oil could already be 140 degs. The oil/coolant exchanger allows the coolant to heat the oil, so if the coolant is up your oil temps are most likely up there too.
    It isn't like the oil isn't doing its job to protect the engine even though the temps are not high enough to make the gauge needle to move. If it wasn't then your would have nothing but damage just from letting it idle.
    Do you seem me scared to do it on a 600whp car that is moving at near 140 mph with low oil temp readings?
    Jun 04 2007
    Austin/DFW, TX
    Thanks Mike, at least I feel safer of when to "boost". But what about turning it off quick?
    My 5-Speed Swap DIY
    - B6 USP
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by biketsai View Post
    Drive to cool down or listen to a song for 3 minutes. Driving it to cool down in a regular fashion for 5 minutes is the easiest.
    Jul 07 2004
    socal
    You want the car to cool down for 1-2 minutes after getting out of boost, this can be done by driving easy like a cool down lap or just letting the car idle.
    When I run the car at the track my cool down time is the drive down the return road, once I get to my pit spot I turn the car off.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Someone can always stall the car after running in boost. Any car manufacturer recommends to start the car and drive it right away. My girlfriend has a VR6 with 100k on it and the car can sit for days and she'll start it and drive right away (gives me the chills and I tend to yell then) but the car is fine. I tend to take care of the 1.8T w/ 131k+ by letting it drop to idle on cold starts and waiting few seconds to shut it off.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    socal
    Quote Originally Posted by nebone22 View Post
    Well letting the car idle to warm it up is just a huge waste of time and gas, plus all your doing is causing more polution. Driving the car easy is the best way to warm it up. Now revving he car up right as you start it up would be bad since not every part in the engine will have oil at that point.
    Sep 24 2005
    always in design
    Very true, especially in winter. You do nothing for the Transmission at all by idle warm up. You need to drive the carm to warm it up properly in winter, hence why even most owners manuals for BMW's and Audi's recommend getting in and driving the car.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Oil doesn't really start working until it is about 150 F which is why the gauge starts there. Idling has extremely low cylinder pressures and the rings are pretty much along for the ride. Run a car hard before warming it up and you can spin a bearing, prematurely wear the rings or cylinders, and even wear the cam journals. Maybe you've just been lucky or maybe it is the short mileage but I'm surprised you haven't had problems with main bearings or losing compression.
    One of the worst things you can do to a car is beat on it when cold. Synthetics help but they are made of magic and have a normal operating range of 150 to about 250-275.
    If you take a look in the owner's manual it has shorter oil change intervals for severe driving. This is often described as frequent short trips. Long freeway drives show the engine almost no wear. The vast majority of engine wear is the first 30-60 seconds after startup.
    Jim
    I Do Werk.
    Jul 07 2004
    socal
    Quote Originally Posted by onemoremile View Post
    LOL, it must be that I am just lucky.
    I run nothing but Redline oil and do compression checks before and after taking the car to the track. Been doing that since I went 2 liter 6 years ago and have never had a loss of compression after a track day or while the car was in my hands.
    Who said anything about running the car hard 30-60 seconds after starting the car? It takes longer then 60 seconds to get the coolant up to normal temps. The car doesn't need to sit at idle for 5 minutes just to drive the car.
    Jan 25 2006
    A4 2.0T
    MD
    Oil needs some temp to flow correctly..........
    Also, Mike if you started your car up in 32F weather you would be a little more concerned about warming the car up correctly...
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Winter is a different story.
    Whats the demage if a thermostat opens too early and car runs at 60 degrees instead of 90 for a few months?
    Jul 07 2004
    socal
    Could cause the car to run rich all the time.
    Quote Originally Posted by Don Supreme View Post
    Yes. But it flows enough even when we first start the car and by the time the coolant temps are up the oil is flowing pretty good. This is when a oil pressure gauge comes in handy and something I have been running since going T28 back in 2001.
