Results 1 to 8 of 8
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    Going to clay bar for the first time...
    I just bought meguiar's smooth surface clay bar kit a couple days ago, and the next time i wash my car i'm gonna pull it in to the garage and do the clay treatment afterward. Are there any special techniques or important things that i should know before i start? On the box it just says to "rub bar on paint surface" or something, so what's the best way to do it? Should i do small circles like when i hand wax the car, or maybe parallel downward strokes? I'm not sure which would be best.
    Here's a picture of my car, the paint is already in pretty good condition but of course there are some problems that i really want to address.
    Thanks in advance!!
    {99.5 Avant}
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Going to clay bar for the first time...
    after i wash the car, i just give it a quick dry. it's ok if its a bit wet. just use alot of detail spray when claying, it needs to be well lubed. also, go ahead and clay the glass. after i clay the whole car, i give it a quick second wash.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Try to avoid doing it in direct sunlight or else the detail spray will dry up and the clay will be rubbed on with dry contact which is bad. I normally just do it in lines back and forth about 5-10 times. Feel the car surface and see if it needs to be clayed more than other pieces. You'll know its good when it feels as smooth as glass. But make sure to keep the surface lubricated, you dont have to over do the amount of spray, but just dont have too litte
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Try not to drop the clay!! Other than that, just keep the surface lubbed up.
    May 21 2008
    az
    thanks guys
    {99.5 Avant}
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    i have the mequires clay bar and i'm not really happy with it. if you have anything other then water spots, i've found it doesnt completely take itout as its not a hard grit or whatever. so i've been trying to find a 3m bar that is a bit harder.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Dec 16 2007
    San Francisco
    Cut your clay into 3 or 4 pieces. That way if you drop one you still have backup bars. In general, if your car is in decent condition, you won't need an entire bar. You don't need to dry the car after washing to use the clay.
    Use a lot of lubricant and inspect the area for debris/grit/sand to be clayed before proceeding. Look at your clay before using, it might have picked up some dirt during the process. These will scratch/swirl you car.
    I usually clay in straight lines and don't use excessive force when claying. I also suggest polishing the car after claying to remove the swirls.
    May 21 2008
    az
    Alright so yesterday i did a wash, clay bar, and wax.
    Damn does the car look great. The clay didn't get every single speckle out of the clear coat, but the paint looks better than i've ever seen it. It's smooth as glass, the metallic flake is standing out way better than before, and the body lines appear to be much more crisp and defined.
    Plus i still have 1/2 the bottle of quick detailer and a fresh bar of clay that i didn't use, so i'll probably do it again after a couple of washes.
    Here are some pictures after the clay and wax.
    {99.5 Avant}
