Results 1 to 3 of 3
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Headlight disconnect - help a noob
    I want to switch out some bulbs in my headlight (DRLs in bi-xenons), so it looks like I've got to take the whole unit out, but I'm having trouble with the wiring harness... is this just a straight pull back and I'm a wimp, or is there something I need to do to disconnect it first?
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Re: Headlight disconnect - help a noob
    There is a little clip sort of thing on the top. Use a small flat head to undo it and then it should pull apart with not much force. Also, my wires were zip tied to the headlight case too so you will have to cut the zip ties.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Jul 26 2008
    Marysville, WA
    Thanks! Turns out I didn't need to pull the headlights... I didn't think I could get the access cap off, but I did.
    The results: not very bright, but looks a heck of a lot better.
