Results 1 to 7 of 7
    Established Member Two Rings stilldubbin203's Avatar
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    Forge 007 causing surging!?
    ok i installed my forge 007 on my 99 a4 and now im getting really bad surging when i let off the gas (rpms drop to around 300, sometimes stall and then go back to around 1000 or so) I tried it with every different springs, shims, and even backwards and it doesnt help it. I put my stock one back in and it runs perfect. Has anyone else had this problem or heard of this and possibly know what to do to fix it?
    SoCo Dubs Bitch!
    99.5 A4 1.8TQM - / GT2871r elim. \ / Tapp Tuned \ /ATP High Flow Turbo Manifold \ / FMIC \ / siemens 630cc \ ATP Hard TIP \ Coolingmist/Labonte Meth injection \ Fprd Lightning Maf \ / stasis coilovers \ /StopTech Rotors + Hawk Pads \ / tyrolsport afpr \ / borla catback \ / DIY intake \ / clear corner mod \ / 8000k hid's \ / vdo center vent boost gauge \ / s4 bumper with shaved center grills \ / aem wideband \ / 18" RPM 505 Wheels \ / Forge 007\ /Turbo XS MBC \
    Dec 05 2007
    Re: Forge 007 causing surging!?
    Sounds more like the diaphram inside needs to be serviced. Take out the DV, take a rag and wipe the entire DV. Then grease (mobil 1 synthetic) the outside of the diaphram (I use a pretty nice amount to keep my mind safe knowing that I placed enough), inside wall of dv and a little around the top rim of the DV. Use the yellow spring, seeing that you have a k04 and all should be well. But it seems like the diaphram of the dv is not sliding well and needs servicing.
    *note-the forge dv is supposed to be serviced at least once a year
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    It's brand new, I don't think it had to be services
    SoCo Dubs Bitch!
    Registered User Two Rings
    Sep 04 2007
    MK5 GTI
    Orlando FL
    How many pounds of boost is your setup making?
    Chip? Exhaust? What other mods?
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    Im running 22 lbs on a tapp tuned gt2871r elim
    SoCo Dubs Bitch!
    Sep 04 2007
    MK5 GTI
    Orlando FL
    My suggestion would be to use the Yellow spring with 1 shim installed in either orientation.
    It should work fine.
    The only issue might be if the cap isn't tight and there is a leak or one of the o-rings isn't sealing or possibly a leak with the vacuum line to the top of the valve. Just pop out the piston to double check it before you reinstall it and then check that line.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah its the wrong spring. sounds like its not holding and diverting too early
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
