Results 1 to 24 of 24
    Feb 17 2008
    Question Intermittent flashing battery light
    I started getting this on my way in to work this morning and on my way home. Its intermittent, just kinda comes on for a second then goes off, not steady on. I just charged up the battery so i'll see if it comes back on. I guess my next thing to do is have autozone load test the system. This should give me a definate answer as to if its the battery or the alternator, correct? Its an 02 a4 1.8t.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: Intermittent flashing battery light
    Is this the battery sign that pops up where the radio station info would be on the dash? I'm having the same problem and after three batteries I'm finally changing my alternator. Hopefully this is the fix.
    Some fast things and some slow things
    ~Josh~
    Feb 17 2008
    Its a little red battery symbol on the gauge cluster, just outside the 'box' where the radio station stuff is..
    Feb 17 2008
    hi?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Mike02A4 View Post
    hi?
    Get a multi-meter and check your battery output. Fully charged it should be around 12.6 V. with the car running it should be charging around 13.5 V to 14.1 V. If not you may need a new alternator.
    Edit: And if you don't have a multimeter I recommend this one: Friggin' thing is awesome!! Clicky click It even has a built in IR scanner!
    Feb 17 2008
    It was 12.55v when I checked it. I recharged it yesterday afternoon and drove it but the light never came back on. I have not checked it with the meter since charging it. I will try that tomorrow both on and off. An alternator job looks like a bitch on these cars..
    I wonder since I do a lot of short trip local driving, that that could not let the battery fully charge?
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I had the same problem, good alternator, good battery, ended up being cut control wire from alternator. Retapped and problem solved (after weeks of bothering me)
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    ur alternator is goin bad..
    Dec 28 2006
    Western Maryland
    If it checked at 12.55v it sounds like the battery is OK. Be sure to check the output while the motor is running. A low battery usually won't give you a warning light. A faulty alternator will. Also be sure to check the belt tensioner on the serpentine belt to make sure the belt isn't slipping.
    Good luck!
    Feb 17 2008
    I will do a running volt test tomorrow. I checked the belt and its tight. How tough of a job is the alternator?
    Dec 28 2006
    Western Maryland
    Not too bad. You can use the first part of this DIY to see what it entails: Clicky click
    Feb 17 2008
    Here are my Volt readings..
    Car on: 14.1v
    Car on with a/c on full blast and headlights on: 13.3v
    Whatcha think?
    Dec 28 2006
    Western Maryland
    Car on: 14.1v
    Whatcha think?
    It sounds like the alternator is working properly. Is the light still coming on?
    Feb 17 2008
    No the light hasn't come on since I charged the battery saturday afternoon.
    Sep 07 2007
    San Francisco, CA
    I've had the exact same problem for the past couple of weeks. The flashing actually seems to correlate to when I hit bumps in the road. This leads me to believe that it is most likely some sort of wiring issue somewhere, probably just a wire that needs to be retapped or replaced. I haven't experienced any issues as far as performance or functionality is concerned.
    Dec 19 2007
    York, PA
    do you have a heatshield from matt?
    Sep 07 2007
    San Francisco, CA
    As a matter of fact I do! Is that what the cause is?
    Dec 19 2007
    York, PA
    Quote Originally Posted by grimlock View Post
    yea...its rubbing through a wire at the bottom of the heatshield...the one thats steel braided...left, next to the turbo/exhaust. This is causing a short and making the light go off. I have the same problem and need to figure out how to fix it. I knew EXACTLY what your talking about with the bumps in the road setting it off, etc. Arent you glad i chimed in?
    Sep 07 2007
    San Francisco, CA
    Quote Originally Posted by n7plus1 View Post
    Haha, definitely. Saves me from going on a wild goose chase! If it's the bottom of the heatshield that's rubbing, what about just wrapping a strip of electrical tape on the bottom edge, would that work?
    Dec 19 2007
    York, PA
    sure, until it rubs through that...im not sure what i want to do yet...i might try to relocate the wiring..or cover it with something else.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    always nice to see the "Clicky click" again
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Just trim the heatshield until it clears the harness.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2008
    I just checked my voltage and it was a little lower than it was this afternoon. It was 13.9V at idle. Normal for it to be lower or am i just being paranoid? I also heard some sort of random clickign noise comming from the alternator area. It was random and intermittent. The low battery light has NOT came back on yet..
    Jun 06 2019
    BMW 335D, the wife's, a few Honda VFR's
    Oakland, CA
    I'm super lost here folks. I have an 03 1.8t quattro 5 speed manual. Have a good battery tested with multimeter at 12.55. Replaced the alternator and starter 2 days ago. Alternator reads 13.82. I'll be posting this in the no start thread as well because it won't start. There's an upgraded head unit to give bluetooth connectivity to the factory Bose sound system. The ground wires have all been replaced as well as power from alternator to battery and battery to starter. Now on top of not starting the battery light is flashing. A push start works and it runs but this is killing me. Help
