Results 1 to 13 of 13
    Aug 05 2007
    Miami,Fl
    out with the old in with the new
    So basically customer had a ATP GT2871R now the he wants an gt3076R car is a 99 audi a4 wagon AWD. We will be putting some IE rods, Unitronic 630cc tune A&L Performance Tubular manifold, A&L 3in turbo back exhaust, A&L inlet and A&L charge pipe the hot side. Here are some pics from what we have done.
    Out with the old GT2871 ATP for the lost
    New GT3076R Precision Turbo
    Collector being made
    More to come
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: out with the old in with the new
    You should have chosen a anti surge compressor housing.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    you will need more space for the TIP and the MAF unless you go Standalone and delete the maf.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by pipe7284 View Post
    There's room if the TIP turns a 180* and puts the MAF and filter above the wheelwell.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Looks nice.
    Are you planning to brace that manifold?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Those bolts are never going to last.
    No wg flange?
    Boy I wonder what that manifold looks like.
    Aug 05 2007
    Miami,Fl
    Quote Originally Posted by GetBoosted84 View Post
    Looks nice.
    no sir
    No wg flange?
    which bolts
    the wastgate flange has been put on it
    Jul 07 2004
    socal
    Quote Originally Posted by mk4futurayellow View Post
    no sir
    which bolts
    The bolts in your picture.
    Well the WG flange isn't on the manifold in the pictures you posted.
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Nice fab job, welder by day?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    No wg flange?
    Wastegate? What's that, I control boost with my right foot.
    definitely a good idea to use some bolts designed for usage with the heat of exhaust manifolds.
    Jul 07 2004
    socal
    Quote Originally Posted by manufan View Post
    He owns the shop A&L, he is posting about a customer car he is working on.
    Aug 05 2007
    Miami,Fl
    those bolts are for mock up, wastegate flange is already installed, just need to update the pictures, have 7 BT cars that need to be out by friday this week with built motors and all of them have manifolds, downpipes with dumptubes that go with it
    Aug 05 2007
    Miami,Fl
    From an Iphone
    more to come
