Results 1 to 6 of 6
    Veteran Member Four Rings VonPooper's Avatar
    Feb 10 2007
    4RUNNER
    HELP! How to remove 18mm sub frame bolts?!
    Trying to remove the 18mm subframe bolts but there is no room. They run straight into the under-carriage. Do they need to be hammered\bent or what guys?
    EARTH PEOPLE.
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Re: HELP! How to remove 18mm sub frame bolts?!
    The ones for the control arms?
    Feb 10 2007
    4RUNNER
    YES!
    EARTH PEOPLE.
    Sep 19 2006
    ND
    drop the lower subframe bolts(the ones that face down, then pry it down and little) and you should be able to slid them out. Thats how I did, not sure if that is the Audi approved way to do it.
    Feb 10 2007
    4RUNNER
    got it...thanks bro.
    EARTH PEOPLE.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    I did a lot of hammering with small steel pipe on the bolt of the control arm facing up. Took awhile but it finally came off, use pb blaster to soak in between. For the other control arm, hit upward on arm. Again use pb blaster on bolt.
    Also try using rubber mallet to on beat arms if steel hammer with rod don't work
    2015 B8 SQ5
    Click Here
    Past
