Results 1 to 21 of 21
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Cracked APR snub mount
    So I took my car in to have the headgasket and control arms done. Due to some miscomunication they also did the timing belt, pumps and all that good stuff. I guess now I don't need to do anything for a little while unless it breaks. One of the things the guy working on the car found was that the APR snub mount that was in the car was completely destroyed. By that I mean that the mount had snapped in half. Has anyone ever heard of that happening? I'm glad he found the problem though. The car drives like a totally different car.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Cracked APR snub mount
    Same thing happened to my friend in his B6 S4, split that thing clean in half. Havn't really heard it before on a b5 though.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Active Member Four Rings
    Dec 11 2006
    Boston
    Happens a lot on A4's. Pretty typical of the APR snub.
    Stage 3+ RS6's
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    wow. didnt know these things could crack. how long did you have it installed?
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    I have the APR Snub mount. Maybe I should inspect it!?
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Jun 23 2008
    NC
    They guys that found it weren't really sure what could have caused it. It's been in a couple of years. It's the first time that they've seen a APR snub mount that broke, but I'm sure it's happened before. What could cause it?
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by Talon Load View Post
    It wasn't blessed by Issam@034
    l gotta-- l gotta get
    a form from a scientist.
    Jun 23 2008
    NC
    Quote Originally Posted by TommyGunn View Post
    Can't argue with that.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I run a vast snub and and it is great,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Oct 05 2006
    Baltimore, MD
    I had it happen to mine when my other motor mounts were in bad shape. It was basically doing all the work holding on to the motor.
    Veteran Member Four Rings SurferD's Avatar
    Apr 30 2007
    18Forester XT touring, 03-F150 XLT, 71-240Z
    Orange, CT
    Just found mine cracked.
    Currently: 2017 Q7 Prestige 3.0 with APR tune.
    Formerly: 2007 S4 Avant 6MT; 2002 S4
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    get the vast snub, it works great, have it on both my S4's.
    Oct 06 2004
    Minnesota
    Did you end up paying for the full TB job? I would be pretty pissed...
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Dec 17 2006
    2000 A6 2.7t 6mt
    Berkeley / Palo Alto
    I would go 034+cage for the snub, it works for me!
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    i have apr mount and rs4 motormounts. i think that would crack if your others were bad but if not apr should be refunding that.
    Veteran Member Three Rings awtst3.a6's Avatar
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    I had the same thing happen to my arp snub mount with 10-15k on it. When the motor was pulled it was seen as a POS
    auto GT a6 - is here.....
    "I compare it to a centerfold model.Just because her measurements are great doesn't mean she's a good lay"
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Time for some Stern motor mounts and snub mount to take away all that drivetrain motion!
    May 09 2008
    NSX
    Huntington Beach, Ca.
    Are the APR (or other) snub's only cracking when they are installed without the benifit of stonger motor mounts being added too?
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Quote Originally Posted by Mike@PureMS View Post
    My APR had roughly 30K before being destroyed. It was paired up with RS4 motor mounts too.
    I switched to Stern!
    Established Member Two Rings CTAudiDriver's Avatar
    Mar 17 2009
    ME
    034 snub mount and bracket FTW!!
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    034 snub mount / cage + stern engine mounts = win
