Results 1 to 6 of 6
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    Anyway to adjust Boost via ODB on REVO BT?
    Hi fellows!,
    i know you can adjust timing via lemmiwinks, but anyway to adjust the boost (without the SPS, hehe:P) ?
    Best Regards,
    star
    A4/B6-2001 [Eurospec]
    430cc Genesis //GTRS// REVO //ATP// CUSTOM 3" EXHAUST w/ Magnaflow Mufflers //BSR OPTIFLOW INTAKE// FORGE SPLIT-R //Neuspeed Xtreme TIP// Racetec FMIC //Hitachi E//
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Anyway to adjust Boost via ODB on REVO BT?
    manual or electronic boost controller. you can get a manual one for like 50 bucks.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Nope, not thru with ODB port unless you have a SPS Select or SPS3
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Didn't you have a long thread covering this already?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Oct 17 2007
    A4 GTRS
    Norway
    Molotov, no that thread covers the fact that he crappy Forge UNOS does not work (either that or the minimum setting is like 1.5bar)
    Feb 24 2007
    Burlington, Vermont
    did you try the other spring? maybe yours came with the stronger spring pre installed?
    I didn't try cranking it all the way to "-" but when I first installed mine it was at 17psi, then cranked it to the "+" and was at 25 psi, fine tuned it down to 22psi... the thing works great.
    - Scott
    Das Build Thread
