If you want the ultimate stopping power, the Keramikbremsen carbon/ceramic composite brakes from quattro GmbH are just what the doctor ordered.
Translated from the Audi Deutschland website:
"Ceramic brakes offer not only quadruple the life span of conventional steel brakes, but also higher brake performance and high fading stability. After repeated braking, for example when driving on a sporting secondary road, the brake performance does not diminish.
"The unsprung rotary mass at the wheels are reduced by approximately 20 kg/45lbs (50%) over conventional brake disks and the result is noticeably higher driving dynamics and agility.
"AUDI ceramic brake disks consist of carbon-fiber reinforced ceramic. This material composition contains Silicon Carbide as the basic material, which is very hard and resistant to friction. In it are embedded high-strength carbon fibers, which effectively absorb material tension and stresses.
"The life span is quadrupled opposite an identically constructed brake disk from steel: The high abrasion resistance of the ceramic disks means a lifespan of up to 300,000km/185,000mi. Additionally, the extreme surface hardness of ceramic makes the brake disks resists road salt, corrosion and rust."
Kit is for front and rear and includes:
- 380x38mm drilled ceramic rotors, front
- 356x28mm drilled ceramic rotors, rear
- Six-piston monoblock Brembo calipers, front (grey metallic color with signature "AUDI ceramic" logo)
- Four-piston monoblock Brembo calipers, rear (grey metallic color)
- Composite brake pad set, front
- Composite brake pad set, rear
- All related lines & mounting hardware
- Installation instructions on CD
We are importing these packages directly from Audi AG and the kit price will be $27,500. Click here or on the pic below to order...
