Results 1 to 15 of 15
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Small purchasing dilemma!
    So,
    I have a small dilemma, I get my PFD next week on Friday and I want to get my K04-15 except no one has them in stock.
    So do I start to pick up the supporting modifications or just wait? The cost of the K04-15 is not bad so I can pick it up whenever but I figured hey inflow of money why not.
    With that being said the supporting modifications I am looking to pick up are –
    AWE Exhaust
    TIP (Manufacture unknown currently need to do more research)
    AWE FMIC
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Jul 06 2004
    Re: Small purchasing dilemma!
    For a K04, you also need or may want the following additional items:
    DV
    TIP, most ppl suggest Forge or Neuspeed Xtreme
    Injectors
    Test Pipe or High Flow Cat
    Ported and Polished Exhaust Manifold
    Throttle Body Hose
    K04 Specific Software Flash
    Upgraded Clutch
    Colder Spark Plugs
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    what's your budget? you might be able to swing a gtrs setup off the classifieds or even new if you have enough cash...
    Mar 04 2004
    Alaska
    Sorry I forgot to add in, I just finished a water pump, thermostat, and timing belt change. During this time I installed my forge 007 DV. Installed NGK BR6E (part number?) plugs, I have already talked to my shop about software upgrade. Contacting audizine member on injectors.
    Now is the ported and polished exhaust manifold really needed?
    My budget is sitting around 5K. I am only going to go up to the K04 because I already have a power house that I have been driving. Just want a little more power then I had stock and the K04 seems to be the best for my liking.
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Jul 06 2004
    ported and polished manifold isnt necessary.....but it will help squeeze a little more power out of the k04. you can also get it ceramic coated to help keep under hood temps down.
    Apr 27 2004
    Seoul
    if you have a powerhouse, just stick to stage 1+ and call it a day. no need for a k04 if you're going to use it as a daily...
    1+ chip
    386cc injectors
    turbo back exhaust
    fmic
    that should be sufficient...and save you a couple bucks.
    Dec 06 2007
    5k? i got the solution for u:
    http://www.ecodetuning.com/shop/cart...t_detail&p=504
    add about $800? for an exhaust, $750 for the install, and $300 for a TIP and wallah u got a BT and 350HP
    -Kirk
    BetaAlphaTau Member #58
    Jun 30 2007
    Raleigh, NC
    ^350?
    lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    ^^^ Crank!
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by Killerteve View Post
    ^^^ Crank!
    still not right. well... i guess on a totally basic setup. just seems so low
    The Awesome™
    Dec 06 2007
    ^^correction 400hp haha maybe if u rampage the turbo.
    -Kirk
    Jun 08 2008
    Calgary AB Canada
    ^ woot! thats what ill be getting soon.
    I finally gave up on getting a k04
    Mar 04 2004
    Alaska
    No worries on install prices I can do it all myself. So that will save me a couple.
    Dropping the car off the jack stands today, once I put the front clip back on. Got my engine mounts and boost gauge I will be installing today.
    Is there a lot of modification needed to fit the GTRS kit? It could be an option.
    Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Jun 08 2008
    Calgary AB Canada
    pretty much everything youll need for a k04 + a clutch
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Okay...
    You will need (100% needed)
    -injectors
    -programming (ko4, NOT 1+)
    -turbo
    Helpful additions
    -Exhaust
    -FMIC (these include a TB hose)
    -TIP (Depends on what year...)
    -Plugs
    -Boost Gague
    Not needed until something breaks
    -Clutch
    4Runner, Rs5 and Alfa Guilia QV
