Results 1 to 31 of 31
    Jul 31 2007
    99 Audi A4 2.8 Quattro
    peg city
    abs module rebuild question
    Hi, ive been reading a few posts about resoldering the abs module? Ive got the usual abs and ebrake light flashing. I was wondering if anyone knows more about soldering the module to repair it? What exactly needs to be done? Any input would be much appreciated. thanks
    Re: abs module rebuild question
    i can do it for you. hit me up.
    contact via email please.
    Jul 31 2007
    peg city
    thanks. but i was just wondering if anyone had any info about what is required to be soldered? im lookin to see if i can do it myself first, as im located up in canada and i dnt want to deal with customs hassels thanks
    i hate shipping to canada. super pain.
    Senior Member Three Rings fernando's Avatar
    Mar 06 2008
    01 A4 1.8T, 1998 Volvo S70 T5
    Maple, Onatrio
    Quote Originally Posted by kmongru View Post
    the hardest part is opening the module up.....once you open you it will be able to see the solder joint that needs to be repaired... just take your time with the soldering....
    GT2871R *Kinetic Motorssports FMIC * VME 4300 HID lights * Turbosmart DV * Revo BT Tune * APR catback exhaust system * custom vent boost gauge * custom vent wideband gauge * zimmerman crossdrilled front rotors with Hawk HPS pads * SB Stage 4 clutch * Neuspeed shortshift kit
    Jul 31 2007
    peg city
    awesome thanks alot, ima start on that asap! hopefully it works out
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    yeah i would also be interested on how this works out for you. take some pics.
    why didn't i buy a rs4 gill when they were $60
    Oct 29 2008
    '01 S4, '90 90q20V, '98 A4q
    Virginia
    Quote Originally Posted by fernando View Post
    I do this repair relatively cheap as a service to the audi community because as an owner, it infuriates me that Audi refuses to acknowledge this problem. It's more complicated than that. Opening the module up is by far the easiest part. You will need extremely steady hands, a microscope to do the repair along with very fine tipped /heat controlled soldering irons and special soldering materials. Email me for more info: [email protected]
    If you've never done this repair before and are trying it for the first time, I guarantee you that you will brick your module. There is literally no room for error.
    and you charge $100. and i charge $50. :)
    Oct 29 2008
    Virginia
    Quote Originally Posted by k0mpresd View Post
    The materials I use nearly cost that much! My scope, irons, and tools cost me well into the thousands! Anyway point is, I'm not making any money on this. Maybe I am just overly paranoid about how I repair these things because they are so delicate. I put in a couple layers of redundancy. The repair usually takes me about 2 hours and I cover return shipping to usa/canada and warranty my work.
    But I'm glad to see people not having to sell out a thousand bucks at the dealer anymore!
    Senior Member Two Rings slayerrule's Avatar
    Nov 02 2006
    50 trimming
    sloatsburg, new york
    its 50-50 repair.... sometimes they can be easily soldered but sometimes its something else. i repaired mine successfully, tried to do the same on my friends car and it didnt work. if you want to try i can hit you up with a diy link but its in russian
    Oct 29 2008
    Virginia
    Quote Originally Posted by slayerrule View Post
    I would never say the solder repair is easy. It's pretty much impossible if you're trying to do it with regular pb-sn solder and rosin-core (I did it once, but I have years of re-work experience, and decided it wasn't worth the effort, so moved on to creating another solution). I contracted with a company that custom-made a special chemicals and solder for me to do the repair. I also typically re-inforce everything with a silver epoxy that costs $125 per ounce! Then I have some more costs in sealing and water/heat-proofing the module That's the reason I'm saying I charge $100/module and am not making any money off of this. I don't really see anyway to do it for less and have a result that will last.
    I would not attempt this as a DIY without a lot of experience in circuit repair and a re-work station or at least some proper irons and a scope.
    Nov 02 2006
    50 trimming
    Quote Originally Posted by sidespar View Post
    dude im not saying anything against you im just saying thats a 50/50 shot in getting it repaired that way. ive seen thosee modules go bad and not because of broken connectors. it does takes a bit of time. i know what involves in repairing those. i would say that you are actually under charging for this repair!
    Established Member Two Rings diablooffire03's Avatar
    Jun 21 2008
    N. New jersey
    I had mine repaired for like 125, so far so good. One thing I noticed is the location of the module. Its right next to the windshield washer fluid. So when you poor in refills its very easy to spill all over the module. I dunno if that would effect it over time, but im sure its seen it fair share of spills onto it.
    05.5 Audi S4
    01 Lexus IS300 Turbo
    08 IS250AWD SOLD
    94 6spd single Supra SOLD
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    I need mine done. was going to send it in to module masters or that other place, but I didn't know you guys do it too.
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Feb 09 2007
    00 S4
    MA
    i tried to do mine,, and it worked, for a while, then failed again. There are alot of very, very tiny wires that you cannot break (or see) or you will have a permaABS light.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Nov 02 2006
    50 trimming
    Quote Originally Posted by Blake260 View Post
    you can fix those tiny wires as well
    Feb 09 2007
    00 S4
    MA
    o, i know you can... It would not be very pleasurable to do, especially without the right tools.
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    is it the box under the rear seat or or the one in the engine bay that usually causes the light show?
    -06 A4 2.0T
    -97 A4 1.8T
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    In the engine bay. Just took mine out today. Not to bad of job. Mailed it to Modulemaster.com . Price is high @ $200 but it has a 5 year warranty.
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    what EXACTLY goes wrong in these modules? my abs/brake lights are going nuts too. soooo f@#king annoying!!!! GRRRRRRRRRRRRRR
    Feb 09 2007
    00 S4
    MA
    there is a write up somewhere, maybe on passatworld.com....that explains in detail how to fix it. there are two wires that connect the board to something (plug maybe) they both go from and to the same contacts, one of them can come unsoldered and cause the light show
    Senior Member Four Rings Gdlaszako's Avatar
    Jan 30 2011
    Probably some Black Widows
    I have the same problem and was wondering if you can just fix it with a soldering iron at home. if you have experience?
    Griffin: Free style walker...everywhere
    If that series of events ever happens again, and you guys can quote me on this, someone can come to my house and slap me one (1) time in the face. - Gram
    Jun 30 2008
    Erie, Pennsylvania
    I know how to solder quite well, but these wires...we're talking TINY. As in microscope tiny. Our shop sends them out to kompresd for repair. They always come back quickly and working! Great guy.
    Oct 30 2009
    Miami, FL
    I tried to fix mine too, I struggled with soldering the wire then when I finally got it the iron slipped and tore one of the microscopic wires beside it. I had a magnifying glass, a decent iron and plenty of soldering experience, but it's just too risky unless you have the rights tools and tons of experience.
    Jul 23 2012
    Halifax/NS/Canada
    Good day sidespar, can you still do a rebuild for my ABS controller? And you cover the shipping back to Canada you said? I am in Nova Scotia!
    May 12 2010
    lowell, Michigan
    Matt "sidespar" fixed my b6 module nearly two years ago and it has been flawless. He was great to deal with and incredibly fast turn around, had it sent out and back in under a weeks time. Thanks again.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    I shipped mine to kompresd on a monday and had her back in working order on Thursday! Was jaw dropping
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    theres 2 pretty small wires that break their connection. they are also surrounded by some very tiny human hair size wires. you need a fine tip iron, steady hands, and soldering experience.
    Established Member Two Rings VisionPaintball's Avatar
    Jun 26 2007
    Keyport,NJ
    k0mpresd, pm'd you.
    I hate these cars.
    '02 B5 S4 Avant
    Active Member One Ring BISHILVR's Avatar
    Jan 22 2015
    OH
    K0mpresd if you are still doing the Abs module repair let me know.
