Results 1 to 9 of 9
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Corner of my Front Bumper sagging... easy fix?
    So the corner of my front bumper keeps dropping out of the guide. Is there any easy way to stop this from happening?
    free earl
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Re: Corner of my Front Bumper sagging... easy fix?
    Quote Originally Posted by Insomniac View Post
    I had the same issue, maybe just not as severe. What I did is I lifted it and then pushed it in with some good strength.. You will hear it pop into place. It has been months since it last popped off.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Self tapping screw through bumper into the fender. Can't see the screw and it holds like new.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Most likely only the top or bottom is snapping onto the guide. Once both are on it stays put.
    Jim
    I Do Werk.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I hate those snaps, they're impossible to get right!
    you have to do something like lift it up, put pressure on it, and snap it down while sliding it back to get it back on the bracket.
    i think i ended up just hitting it really hard and it snapped in.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    the PO of my car used acouple self tapping screws, if you go that route, pic your placement well, you can clearly see mine when washing the car and look between the bumper and the fender. looks like poo poo.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Registered Member One Ring Gotbail's Avatar
    Jan 13 2008
    2001 A4 1.8T
    Richmond, VA
    This same thing happened to me. Its the plastic hooks on the bumper guides that wore out. Just buy new bumper guides, I paid 30 bucks for both sides shipped and throw them on. It took me less than an hour to do and it looks like new again.
    Got Bail?
    Custom Bail Bonds
    Serving Central Virginia
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    the po of my car drilled a small hole and used a ziptie to hold it up
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    Same thing happen to me and I popped it back in. Then 2 miles down the road and it becomes popped out.
    I found out that at the bottom of the bumper there's a screw that ties your bumper to your wheel well lining. All I had to do is get a new screw and screw it back in good with the bumper in. Also I made sure that the bumper was forced up a bit so the top hook had a good hook on the bumper.
    Basically without that screw, my bumper would just wiggle out of the hooks.
