although that a/c thing would be covered under warranty, the service plan isn't that bad.
I just glanced over it, but there are quite a few good things on there, namely fuel system clean, brake fluid flush, stuff like that... whether or not it's worth the money depends on you. I would never change my oil at 10,000 miles. Thats is plain bad for any car. I have a company do my oil analysis for me, and based on me driving nicely to and from work, the most mileage i can get out of my oil is maybe 6 or 7k. I change at 5k. Also, the first oil change i did at 3,299 miles because i did not trust the factory oil, and sure enough the test came out and the active additive left was less than 15%, also, break-in oil from the factory is usually a thinner viscosity.
All in all, if you are serious about taking care of the car, get oil changed 5k, which means if you do get the plan, you will have to pay for a few oil changes in between their schedule. Audi charges $150 I think per oil change. I pay under $50 for the filter, oil, crush gasket.. changing it takes 45 minutes or so...
So if you want to have the dealership do all the work for you, YES the plan is great, but if you want to change your own oil, or have a trustworthy shop do it for you, it will be much less. :D any way you decide to do it, I recommend oil and filter change every 5,000 miles and 3,000 for your first one. And always use synthetic with the VW 502 00 approval (i think i typed that right) and I also hear that changing the drain plug once in a while helps too.. but dont know about that for sure.
Hope it helps and good luck :D
