Results 1 to 24 of 24
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Arrow Suspension Setups and Ride Quality, please post experiences.
    Background: I come from driving a fully moded (suspension wise) 98 altima, it rides like a GoCart, pulls 1.02g and the ride quality is nonexistent but it’s fun hell and a small price to pay to keep up with 400hp RWD cars on canyon runs :)
    I bought the S4 as a conformable yet fun weekend/long trips car. I took it out on a canyon run and was not impressed, there is massive body roll and overall the car feels very heavy, especially through S turns. So I want a better handling car and not sacrifice any ride quality.
    I would like to get feedback on suspension setups.
    Which shocks/springs/coilovers/sway bars have you installed and was there any difference in ride quality/comfort?
    Disclaimer: I did an extensive search, what I found were many conflicted posts, I even found conflicts between the same members posing vastly different opinions in different threads.
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Re: Suspension Setups and Ride Quality, please post experiences.
    Although I have an A4, I have the S4 PSS9s on my car. I have been nothing but pleased with the ride quality thus far, and have received no complaints from the wide gammut of passengers that I drive with me from time to time. I typically keep them set on 5 (1 is the hardest and 9 the softest), and this affords plenty of daily driving handling without beating up in any way. In addition to the coilovers, I have Hotchkis RS4 H-Sport front and rear sway bars. The rear is two-way adjustable, and I have mine set on the stiffer of the two. This overall setup provides for dramatically reduced understeer (mash the throttle in second gear on a tight turn, and lurid oversteer quattro slides ensue!), significantly reduced body roll, and an increase in turning accuracy and stability at virtually any and every speed. I can only imagine this handling prowess with V8 power...
    And I came from the stock sport/S-Line suspension, so I am not comparing my upgrades to the 4x4 base A4 suspension. I also have 19 x 8.5 wheels and 245/35/19 PS2s helping my cause in the grip department. This setup has proven to be comfortable and handles as well as I can truly ask of this car. The suspension set to 9 is almost certainly smoother than stock S4 ride quality, with an improvement in handling to boot!!
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Do it right. Stasis Ohlins Motorsports
    Veteran Member Three Rings rpmfoundation's Avatar
    Aug 25 2008
    2012 Toyota Highlander Hybrid Limited (wtf)
    Hollywood Hills, CA
    Quote Originally Posted by CHECKERED View Post
    first and foremost - Altima?? really?? I had that thing long ago.. i mean like 10 years ago.. its a slug. but hey - i am not here to critique.
    anyway so
    STASIS ^^
    H&R - good set up and so is bilstein. Upgrade to RS4 bars, spacers, up the width on tires. ( BFG - Sticky tires )
    I'd say get Tein (but not sure if its available for your car) - it worked miracles on my rice.
    my car is still on AZ... someone else is just driving it (BMO).
    Jun 11 2008
    2008 M3 DCT Gintani SC
    los angeles
    i have stasis sl and hotchkis sway bars....ride quality defently worse...pretty bumpy over broken concrete...thought about going back to stock sway or at leasdt moving them to softer setting...but handling dramaticly changed
    08 M3 DCT - Gintani Supercharged / Akrapovic Exhaust / Brembo BBK / KW V3 / HRE P43 / 3F Engineering Spoiler - Lip - Diffuser
    Aug 17 2008
    Southern NH
    Quote Originally Posted by rpmfoundation View Post
    The car is slow in a straight line, true. But what other cars have rear struts and not gas shocks?
    You have not driven this altima. I have 200lb of stereo equipment in the back, which balances out the car, my friend drove it and swore it was a rear wheel drive…lol..but yes very very fun toy. I can abuse it and drive the piss out of it and not care.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Startup Racing GT's are definitely worth considering. Dunno if you saw my reviews but check 'm out. Combined with RS4 H-sports, the ride quality is far better than stock and performance is considerably better.
    Initial Review
    Track day
    Ongoing Review
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Quote Originally Posted by Cargo8 View Post
    So what people that don't run coilovers on a STREET CAR are doing it wrong?
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Dec 05 2006
    So. Cal.
    PSS9's on m last B6 and they were great expect for the caddy bounce on the freeway. I'm sure that corner balancing could help to alleviate the problem.
    If you tdo thePSS9's, make sure to do the spring perch mod.
    Aug 17 2008
    Southern NH
    What about sway bars, do they stiffen the ride quality?
    Jun 11 2008
    los angeles
    when i just put sways on was a lil stiffer but hardly noticeable...helped rid a lil understeer...took my car out for real last few nights (just installed stasis sl and new wheels) and i was taking turns that normally my cars tires would be screaming and understeering..now at same speed car's not even trying, no tire sound...feels amazing..slowly pushing it...feels ridiculous
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    You have plenty of options. Just depends on your budget. The best of the best is Stasis Motorsport, however.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    Quote Originally Posted by Stevelev View Post
    I have the non-startup version of the Vogtland Coilovers and the h-sport rs4 sways too, and I agree. I think the car rides better then stock and performs way better
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Apr 27 2004
    On my B6 A4, I felt a slight degradation of ride quality. What I noticed happened few and far between but was a slight loss of independance between the right and left (rear) so some bumps seemed a bit more prevalent than in the past (likely due to the very soft Stasis SS coils). The improvement in handling was substantial so the benefit far outweighed what was barely noticeable. On my S4, I noticed no degradation of ride when swapping in the RS4 h-sports
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    whats the spring perch mod??
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by fitzS4 View Post
    Bolting the perch to the car so that when you go to spin the height adjusting ring, the perch doesn't spin with it.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    I hear Ohlins are the bomb-diggity. Wouldn't know myself tho.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Registered Member Two Rings Lake Powell's Avatar
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Does anybody have any experience with Stasis verses the KW on a case by case set up?
    I'm asking because I'm real close to either getting the Stasis SL package or the KW V3 set up.
    This will go on my 07' RS 4
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Bump!
    Bueller? Anybody?
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    I have experience with the V3's and loved them. I have not tried the SL's though. The quality build of the V3's may help in the Utah winters since they use a stainless body on them.
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Thanks Jet Blue, good info!
    Are you with JB?
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    i know you're trying to be helpful, but this post helps nobody. So what does "do it right" mean for you? how adjustable are they?
    as someone new to the audi community, i have heard lots of good stuff about the Stasis coils, but i haven't heard specifically why individuals like them. each person has different tastes, and uses for their car. some people like ultra stiff settings for ultimate road feel at the expense of ride comfort and road noise. Others (like myself) purchased the A4 for a fun daily driver, that's occasionally used to transport clients, and do an occasional spirited drive through tight curvy roads.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by p1nk50ck View Post
    do a search, this has been covered numerous times
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    ive heard stasis sl's are the way to go, im on koni's now set to full stiff anf the car is extreemly comfortable, and they go low. suprisingly the tein ss are a good bang for the buck coilover also for the s4, adj dampening to boot.
