Results 1 to 6 of 6
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    How to Remove Front Fender?
    I have removed the bolts inside the engine compartment and the ones on the wheel well. What other bolts and how many do i have to remove in order for the left front fender to come off? A picture diagram would work the best if possible.
    2018 Mercedes GLC 300
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: How to Remove Front Fender?
    Make sure you get the one(s) inside the door jam also. The size is Torx 30 as well.
    Los Angeles, CA
    how many are in there? I got one of them. Any others?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Remove the inner fender liner and open the hood. There are a few bolts under the edge of the hood and a couple more behind the liner and in the door jamb. There are more down at the front edge of the fender behind the bumper. Drill a couple 1/8" alignment holes to make the reinstall much easier.
    Jim
    I Do Werk.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    there is also one underneath the black clip on the fender. three inside the door jam that you get from the wheel well side, and one or two that you get from the inside of the doorjam
    ::2002 S6
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    since my pinch weld is bent and messed up, i had to drill out those two screws in order to take my fender out.
    IG:@steadysupreme
    Pics&Detail
