Results 1 to 6 of 6
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    CHEAP 12v VR6-T or...
    Basically, my friends and I are planning something along the lines of a Gumball Rally.. and thats my motivation to actually build my car.
    So I've been looking around for my options.
    1) Buy an AEB engine, build that and in the mean time drive my car as the DD it will be for a while after the build is finished.
    2) Buy an MkII Jetta, build that.. Enjoy slowness but pure secks in the form of driving pleasure after its all said and done.. Keep the A4 for DD use.
    3) What I thought was totally out of the question.. a VR-T build. I'm not going to say how cheap or where it is, because that would totally give one of you the chance to snag it up haha.. But basically, its a 47,xxx mi 12v VR6. Came out of a wrecked Jetta. Basically, I'd buy it, put it on a stand, mild build, and then have 417 Motorsports fabricate all the mounts and etc for me.
    Now the last option is still very hazy, as I haven't even gotten a hold of them yet to see if they'd even do it.
    So that said, what would you do?
    I want something that looks good, handles good, and is at least worthy of 12's.
    ÖMGHI2Ü
    Photography
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: CHEAP 12v VR6-T or...
    Do you have the money for all of what you stated above? If money is no problem I would go with the VR6 build. You could also fabricate mounts, do everything else needed for the conv. and then just drop it into your A4.
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    034 sells the engine mounting kit
    Registered Member Two Rings
    Feb 10 2008
    RI
    put the vrt in the mk2 it will kill the handling but it will cruiseeeee
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Is this coming from a guy who hasn't even put a chip on his car yet , how bout u just put a big turbo on there..
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Veteran Member Four Rings seank's Avatar
    Nov 14 2006
    here
    My mk2 gti vr6 with a stage 2 vf blower was pretty fun, pulled like hell on the highway but it was a nose heavy pig in the handling department. I occasionally think of building another if that means anything.
