Results 1 to 16 of 16
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Podi-riffic - LONG POST
    So, I bought one of Winston's scratch and dent Podi's on Sunday, and it already arrived cross-country today! I admit that I initially didn't like the idea of the Podi because I was worried about visibility of the instrument cluster. I was wrong. Even with the steering column where I like it, I only lose 0-10 mph visibility.
    Also, for being "scratch and dent" I sure can't find a scratch or a dent.
    I haven't fully installed it yet - it's just sitting on the column without my gauge or the two screws. Why? Because the Gamecocks are playing Vandy, and the Redskins are playing the Giants tonight.
    Speaking of those two screws - holy crap I was pissed. Forget trying to find a long-ass T8 driver at Pep Boys or Autozone. I ended up going to Sears and bought a set of Torx drivers. Here's the problem: they were too damn short to reach the screws in the steering column!!! I could tell I needed about a half inch more shaft. How did I fix it? I dremeled off half an inch of plastic from the handle (it was a regular plastic screwdriver handle)! Moral of the story - you need a loooong T8 to reach those bastards.
    I'll wire it up tomorrow. I coiled up extra boost tubing in the ECU box when I did the A-pillar gauge, and I'm hoping I can slowly pull out enough slack to reach from my existing pod to the Podi.
    Which brings me to - yes, I currently have Martini's custom A-pillar pod. I didn't screw it into the A-pillar like he did, so I could never get the fit just right. I tried all kinds of tapes and adhesives, but it just wouldn't stay on the A-pillar. If anyone is interested in buying it, let me know. I would recommend screwing it in like he did, but wrestling with the A-pillar cover was honestly a nightmare. Here's what I'm talking about if you don't know. Martini sold it when he got a Podi.
    So, that's my unnecessarily long post about my half-installed Podi.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Re: Podi-riffic - LONG POST
    You couldn't find this one?
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    May 03 2008
    Orlando
    Quote Originally Posted by WiZZLa View Post
    I bought these. I think the one you linked to is even shorter than the ones I bought. I dremeled off the green section on the T8 (second from the right).
    Kevin W.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Is there really no scratch or dent on it....anywhere? LOL
    -Sami-
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    if you read my podi install writeup i link directly to a torx driver which will fit... it is not part of a set and can be had for less than $5 at sears
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    May 03 2008
    Orlando
    Quote Originally Posted by martini View Post
    Ahhh - that's the one Wizz posted. I needed a set with the others anyway, and the dremel procedure worked pretty good.
    a4mods.com is your friend.
    Kevin W.
    Jul 10 2007
    trunk
    Thanks for that write-up. It helped a fair amount...except I'm terrible at wiring and I couldn't remove the windshield wiper, so I ripped out the ECU cover instead.
    and for fellow Canucks, "Crappy Tire" has it here and it's actually longer than the one in the a4mods guide by about half an inch.
    Stage 0 minus - .5
    May 03 2008
    Orlando
    yeah, the wipers suck. It took me an hour to wrestle off the drivers side one. Even with that one off, it's a nightmare to get to that back ECU cover screw.
    Kevin W.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    man i did my gauge without a single problem, went right through and the wiper popped right off ...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    May 03 2008
    Orlando
    Quote Originally Posted by OneBadAudi View Post
    How do you access that last ECU bolt? You just remove the driver wiper? If so, do you use a flexible extender to get to it? I can't seem to bend the trim enough to easily access it.
    Also, my driver's wiper seems like the "fins" or ridges are messed up - it's like the piece in the wiper and the piece on the assembly have been stripped or mashed flat. The grooves and ridges don't look crisp anymore. I think that's what makes it such a pain to remove.
    Kevin W.
    Registered Member Three Rings Amze's Avatar
    Apr 10 2007
    2003 Audi A4 1.8TQM
    Phoenix, AZ
    Got my torq thing at sears.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Trust me... there is something I find wrong with each of those S&D units.
    Whether or not you see what I see is another story.
    I'm looking into finding a supplier of Torx drivers and see if I can include one with each kit to help rid this issue of trying to find one.
    In Canada they are available at every Canadian Tire for $5.
    CO
    I also had a hard time noticing any defect with my s&d podi, however, when running my fingers over an area of it you could feel somewhat of an "imperfection". The other thing I found out was that the screw holes were a bit wider towards the bottom causing the screws to be rather difficult to catch and hold. I don't know if this is a result of the scratch&ding version or this is normal.
    I initially had a hard time with this as well. Once you have the wiper removed I used an adapter to attach a T30 torx bit to a 3" extension which was attached to my 3/8 ratchet. I slid this through the hole that exists in the rain gutter to allow the wiper are to attach. This actually allowed me to get the screw out fairly easily.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    That would be a nice addition to the kit Winston.
    [[email protected];2847168]I'm looking into finding a supplier of Torx drivers and see if I can include one with each kit to help rid this issue of trying to find one. /quote]
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by kwimberly View Post
    you can take both wipers off and then remove the plastic cover along the bottom of the windshield... then its a clear shot to the ECU
    thats what i do now... of course thats after the writeup
    it would end up looking like this:
    May 03 2008
    Orlando
    I got the Podi installed! I did find the tiny little smudge that probably made it a scratch and dent one, but it's so small and insignificant that I probably would have sold it as new...
    A few impressions - my gauge is an Auto Meter, and it seems a bit long for the Podi. A little bit of the white metal cylinder is sticking out of the Podi - just a tiny bit. The compression nut sticks out pretty far in the back of the gauge (as does the lightbulb housing) that it just can't cram all the way back into the Podi. When I try to jam it all the way back, the wires get so crimped that the lightbulb turns off. So, I'll just live with it sticking out a little. Oh yeah, and since it sticks out a little at the bottom edge, the angle is a bit off - the top is further away than the bottom - just slightly.
    Also, I was used to the A-pillar mount, and it takes a little bit of getting used to with the new gauge location - it's a LOT closer to your eyes than the dash, so you kind of have to refocus for a second to see it. The A-pillar location was nice for quick glances because you were still looking forward. No biggie - just going to take a bit of getting used to.
    The fit was perfect as far as replacing the OEM column piece - the little fabric piece snapped in perfectly, and the Torx screws tightened the Podi perfectly into position.
    Here's a crappy cellphone pic:
    Kevin W.
