Results 1 to 8 of 8
    Jul 06 2004
    Whats the best air filter?
    I was going to replace my oem air filter as part of the normal scheduled maintenance. But i figured for nearly the same price I could get a high flow aftermarket air filter.
    Ive heard K&N has created problems due to the oil on the filter clogging the MAF. So i'd like to stay away from that one.
    What else can people suggest?
    Sep 02 2005
    Montreal
    Re: Whats the best air filter?
    ITG.
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    If you have searched, you would have got your answer. Most would agree that the OEM air filter is the best way to go. I replaced mine not long ago, and I got it from the dealer for about $30.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Oct 15 2006
    From a few to one...
    Arlington, VA
    have an itg on my b5, but just run oem filters on my b6. didnt really notice much difference in my b5, at least anything that i could attribute to the filter. i did have the filter-oil-on-the-maf problem with the itg, so i dont think its solely a problem with k&n. that was the oiling out of the box, not me re-oiling.
    i say avoid the hassle, just stick with oem. sure, its a bit easier to just reuse an oil filter, but in the end, i dont mind spending a few $ here and there, especially if i know i will never have to deal with oil on my maf.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    I have a K&N Free-Flow Panel that works great, i have been running it for two years without any issue. The oil issue you hear about is when people clean them and apply too much oil to the filter afterward which is then sucked into the MAF, this can easy be avoided if you clean the filer properly.
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    what is the OE company of our air filters?
    05 Triple Black 1.8T Quattro Tip.
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by bigbro View Post
    i believe they are either Mann or Mahle...
    Dec 25 2004
    Earth
    Oil-free AFE Pro-dry!
    http://www.afeproducts.com
