Results 1 to 17 of 17
Thread: Stock Boost
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Stock Boost
    I tried searching before anyone gets their panties in a bunch, but no luck. I am trying to find out what the stock boost numbers would bemy guess is between 8 and 10 lbs. but not sure,
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Re: Stock Boost
    i think its 10-12psi
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Re: Stock Boost
    I'm stock, and I hold 11-12 psi.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Re: Stock Boost
    ^^^^thats about right
    B7 A4.... 394awhp
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: Stock Boost
    stock boost puts me to sleep
    i think theyre right
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Aug 22 2007
    2006 A4 QTM6
    forest hills queens, ny
    Re: Stock Boost
    i thought stock boost is 14-15 psi and chipped ~20psi? correct me if im wrong tho
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Re: Stock Boost
    My stock boost vs. Stasis Chip boost.
    Ambient pressure was 985 mbar (block 113)
    block 115 logs actual boost.
    PSI = actual boost - 985 * .0145
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Nov 12 2007
    Grand Junction, CO
    Re: Stock Boost
    How is the torque curve with the stasis chip? Is it pretty linear? or more a spike at the low end?
    Jul 07 2008
    Chicago
    Re: Stock Boost
    Quote Originally Posted by AudiWxGuy View Post
    There is a good spike a bit over 3k RPM which slowly falls off on the way to red line. Compared to my old B6 S4 it does not feel linear at all but it does feel much better then stock (less linear then stock though).
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Senior Member Two Rings socaljoe's Avatar
    Sep 26 2006
    bunch of junk...and spiders
    Southern Kalifornistan
    Re: Stock Boost
    According to my AWE boost gauge(isntalled before flash), stock was 14 and after chipping (APR91) is 18psi.
    Bone Stock
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: Stock Boost
    On my car stock is also around 14psi, but keep in mind that is with a turbo back, intake, and a bunch of little things.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Jan 16 2008
    Ohio and GTA
    Re: Stock Boost
    Quote Originally Posted by tre View Post
    I never tested my stock, but i got the car chipped with mtm which is a conservative tune at 245hp and 263 tq (pretty similar to stasis). the gauge seems to hold boost at about 17, but ive only tested it the past few days and they have been 90+ degrees out. I would suspect that when it gets cooler into the 70's or 60's i should make another couple pounds of boost.
    DUH! an Audi
    los angeles, CA
    Re: Stock Boost
    10-12 max 12 holds around 10ish
    -randy
    Jan 16 2008
    Ohio and GTA
    Re: Stock Boost
    i just tested at night when it got alittle cooler and i was holding at 18psi.
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: Stock Boost
    I foudn that the stock numbers are easily changed with exhuast and all before being chipped...with my exhuast, and testpipe, id stock boost at anywhere between 10-15, and with the chip turned on im 20-25psi
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Re: Stock Boost
    I'm chipped and spike at 20
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Established Member Two Rings o7S-line's Avatar
    Aug 28 2008
    07 titanium package a4 , 2.0t
    pennslyvannia
    Re: Stock Boost
    i have just an intake and i spike 12 and hold 10
