x-posted on AW
The car is a 2000 4.2 w/ 103k miles.
Randomly now for the past while when I drive the car cold, the first shift clunks HARD followed by the gear selections on the display screen lighting up in all red. To make it shift correctly after that, I have to turn the car off to reboot it. Then it works fine.
Today it happened twice back to back in the middle of campus with all sorts of traffic behind me. After I turned the car off, then on twice, I got a CEL. I had Autozone scan the codes and it brought up:
P0730
Definition:
Gear incorrect ratio
Explination:
Open or short circuit condition
Probable causes:
1. poor electrical connection
2. low transmission fluid level
3. failed transmission solenoid
Another weird thing that I'm concered about is when taking off from a stop and steadily driving slow in 2nd gear, when a LITTLE bit of throttle is given, it jumps down to 1st then back up to 2nd pretty quickly. Also when driving on the highway cruising around 55-60mph, if I punch the throttle, it tries to search for a gear and will sometimes slam into 2nd when not needed and then kick back up to 3rd.
Now I know these cars are known for having tranny problems, But I am not sure if this is something that can be dealt with before anything gets worse.
We already had to replace the tranny on my moms '98 A8 4.2Q (was under warranty thank god) and I'm not wanting to do that with this car either (not under warranty).
Sorry for the long post.
Any idears?
