The information about the 1996 Audi A6 anti theft system is in the BentleyPublishers.com Audi shop manual CD.
Have you tried getting out of the car and locking and then unlocking one of the two front doors.
Have you tried disconnecting and reconnecting the battery? Be sure you have the radio code before doing this.
Do you have a VAG-COM from ross-tech.com?
You make have a bad switch or wire in your rear door at the lock cylinder or at the latch.
I have a 1996 Audi A6 Quattro, with a malfunction in the central locking, anti-theft alarm system control module, V94. However, since I don't have the VAG 1598 test box and the Vag 1598/11 adapter harness, which Bentley says to use, it will be difficult to find all of the faults without a lot of extra work.
Per the wiring diagram, the Starting Interlock Relay, J207, is wired to V94, so you can't simply remove the module. V94 is also wired to the multifunction transmission range switch (nuetral safety switch), F125. These parts, V94 and F125, are very expensive, so try fixing the rear door switchs first. Check fuses S8, S10, S114 and circuit breaker A3. (Bentlley had A2 in the instructions and A3 on the wiring diagram.) Next, get a copy of the CD.
