Results 1 to 3 of 3
Thread: Wheel fit help?
    Aug 31 2008
    Massachusetts
    Wheel fit help?
    Can anyody help me on this? I have a 2000 B5 S4 (stock suspension) and I am not sure about the stock offset. I would like to mount ADR Propulsion wheels that are 19X8.5 with 35 mm offset (front and back). With 235/35/19 General Exclaim UHP tires. Will these fit, or am I going to have problems with the brakes or suspension?
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    Re: Wheel fit help?
    if you put 19" rims on a s4 with stock suspension the only thing you'll have to worry about fitting is yoursef into the crowd.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    Re: Wheel fit help?
    you'll need spacers.. 8mm maybe 10mm.
    -Luis
