Results 1 to 2 of 2
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Aftermarket rim/tire size adjustiablity in VAG-COM?
    So I just picked up some 19's for a steal, and I've relized my speedo is no longer accurate. I looked up a tire calculator online, and it says I'm 3.1% slow. I'm running a 245/35/19 falken 452. I've also noticed a drastic drop in MPG. On stock wheels, i was getting around 27mpg, now it's 24ish. I believe most of that is due to the extra unsprung weight.
    So does anyone know if I can get into VAG-COM and modify a setting to get my MFD accurate? I saw somewhere that you can go in and adjust miles to empty, but have not been able to find out how.
    Did anyone else notice a change going from stock 17's to 18's or 19's?
    I also posted this in the B5 S4 forum...
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Apr 18 2008
    Jacksonville, FL
    Re: Aftermarket rim/tire size adjustiablity in VAG-COM?
    because your speedo is off, your odometer is also off. some of that mileage difference is due to you traveling more than a mile before you odo registers a mile. ...not that this helps you with your problem....
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
