Results 1 to 4 of 4
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: ECS B5 A4 Exact Fit Stainless Steel Brake Lines - Now Available !!!
    Click HERE to order or for more information.
    ECS Exact-Fit Stainless Steel Brake Lines
    ECS Stainless steel brake lines offer improved pedal modulation and stiffer pedal feel over the stock lines. While stock brake lines are fabricated from a reinforced rubber they can still increase in diameter when pedal pressure is applied. The result is a spongier pedal feel as some of the master cylinder pressure is wasted "inflating" the soft lines.
    Braided stainless steel Teflon cored lines offer superior resistance to deformation under high pressure compared to rubber. All stainless lines are manufactured exclusively for ECS Tuning to exact specifications. Finished lines are then covered with a water/dirt resistant vinyl coating greatly increasing safety and lifespan of the line. The ECS Stainless Steel brake line kits are DOT approved and a direct fit for your B5 A4.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    Re: :: ECS Tuning :: ECS B5 A4 Exact Fit Stainless Steel Brake Lines - Now Available
    oooooh nice!
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    be sure you have some line wrenches before you attempt this <- experience speaking
    Senior Member Two Rings genecan's Avatar
    Apr 29 2007
    Bulgaria
    Does anybody have any impression on these already?
    1999.5 A4 B5 1.8TQ (ANB) -> 2.0L AEB EFR 7163 - http://www.audizine.com/forum/showth...ight=evolution
