Results 1 to 10 of 10
Thread: Turbo Problem
    Registered Member One Ring DFS71's Avatar
    Oct 03 2007
    2007 A4 2.0T Lava grey
    Venezuela
    Turbo Problem
    I think the turbo of my 2007 2.0T FWD tipt is not working but no light on, could that be possible? or could it be the program. I feel the car much slower and got appointment for next week. If i have to buy a new turbo i want to fit the BT but is not available yet.
    DUH! an Audi
    los angeles, CA
    Re: Turbo Problem
    ummm, doubt its your turbo...does the car still drive? if so turbo should be working
    way to test, floor it and try to hear your turbo spool, it spools it works
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: Turbo Problem
    pop your hood in the driveway and gun it while someone looks on. i also doubt it
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    Re: Turbo Problem
    boost leak?
    Senior Member Two Rings Raymax_2.0t's Avatar
    Jan 01 2008
    Tulsa, Ok.
    Re: Turbo Problem
    Quote Originally Posted by apatchin View Post
    boost leak?
    x2 Probably the D.V.
    May 20 2004
    More cars
    Never Land Ranch
    Re: Turbo Problem
    did you have your car recently into service where they might have done a TSB and reflashed you back to stock?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Re: Turbo Problem
    there was a recall recently that would have done that, but there is no way the turbo is not working - first you would def get a cel, secondly you would know for sure because the car would barely move.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Re: Turbo Problem
    I think a DV would give you a light If I do remember correctly. What software are you using?
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Re: Turbo Problem
    if it feels slower... check your pcv valve... also look for oil spots near the gas cap and engine.
    if there was no turbo... you should feel a VERY VERY HEAVY slowing down and should automatically go into CEL (limp mode)
    Oct 03 2007
    Venezuela
    Re: Turbo Problem
    I ve been using APR 95 for a year and is due to service 20000k but will be next week.
    I thought was turbo because i push the gas for a fast start and didny do much and got home turn off the car and didnt hear the tubo going off.
