Ok so before i start, this is my setup: 2001 A4 1.8TQ, aeb head swap, manifold, and fuel rail, newsouth phenolic spacer, 034 exhaust manifold, stock K03S, evo testpipe, ghl cat-back, and TT225 (386cc) injectors, and unitronic is writing the custom software (1.3bar). The build up has been going very smoothly for the most part until i encountered a bit of a problem today with the injectors. Originally, 034 gave me injector spacers for the TT injectors because they said that would solve my problem and would allow me to fit those injectors with my aeb setup. The spacers dont really look like they do anything and kind of make the rail setup seem flimsy anyway. But back to the problem, i attempted to but the TT injectors in the new manifold and discovered that they would not fit in the aeb seats because the aeb seats are smaller than the awm's. So i attempted to swap the seats from my awm manifold since the TT injectors need the awm seats and found that the actual awm seat is externally larger in diameter than the aeb seats and will not thread into the aeb manifold. So what im wondering is if there is any seat that will accept the TT injectors that fits in the aeb manifold?
But now that i have encountered this i am actually begining to think of other injector options, because the only reason i planned to specifically use the TT injectors was because i had them laying around from my dads stage 1+ B6. I have also heard that the TT injectors shouldnt/cant be used with an aeb head setup because of the design, so im wondering if i should even use them or not.
So all you aeb guys, maybe you can tell me what the best injectors would be to match this setup that is a direct fit for aeb motors. I was thinking either the 310cc injectors from a pc-16 set up, or i have heard that seimens makes 380cc's also. So basically i need to find an injector that fits the aeb setup, any ideas?
