Results 1 to 7 of 7
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    How do you change the IAT sensor
    I saw on the bently that the IAT sensor is right behind the throttle valve, under the intake manifold.. what are the steps at getting to this sensor? I have an apr bypipe, do I need to take it off to get to the sensor...? can it be taken off without taking off the bumper and core support? when I installed it there was nothing in the way. But ya, how do I get to that IAT sensor?
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: How do you change the IAT sensor
    bipipe needs to unbolt yes. remove rear tires. Unbolt the fuel rail. remove the hood. unbolt intake mani. your golden. skip step 2 and 4
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Oct 30 2006
    B8 A4 Avant 6spd
    I'm just guessing but if you removed the Throttle body, you might have enough to squeeze your room in there with a ratchet and a socketed allen and undo the IAT. A lot less work then removing the entire intake manifold. If you're going to go that route you might as well order intake manifold spacers, knock out two birds with one stone. Just be careful not to drop anything into the intake ports.
    -18 718 GTS
    Feb 09 2006
    Huntington Beach
    little hands might be able t do it but its prety tights in there. spacers would be cool
    Account Terminated One Ring
    Sep 03 2008
    NLasVegas
    Quote Originally Posted by Militant-Grunt View Post
    i would go this route^
    Aug 06 2008
    Canadia
    depending on the type of fasteners it uses it may be possible to remove it after the TB is out.
    Feb 22 2007
    Earth
    I am thinking I will go ahead and remove the intake manifold. I have an APR bypipe.. when I installed the thing the front end was open... I was woindering if it can be taken off and reinstalled with the bumper, core support and radiator, and fans still in place..?
