Results 1 to 3 of 3
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    Timing Belt on a 3.0L 2004
    So, I have to do the job. I have done B6 A4 1.8T before and I was wondering, is there anything in special that I need to take into consideration when doing this job or it's about the same thing as the B6 A4?
    Thank you!
    PS; I have searched a bit but didn't find exactly what I was looking for nor any DIYs.
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: Timing Belt on a 3.0L 2004
    Completely different and number of special tools needed. Wouldn't even consider it unless you have access to the tools. There's 2 big claw lookin gadgets to set cam timing (which can be tricky to install properly......), a a tool to lock the crank and a special socket to reset the adjuster mechanisim in both exhaust cam sprockets. The intake sprockets don't have to be reset.
    Feel free to ask questions if you have access to the tools. Don't consider doing it without. Do it right or not at all type of deal.....ya know
    C
    Aug 25 2008
    Montreal, Canada
    Quote Originally Posted by Affinitive View Post
    C
    Thank you! This is what I was looking for as an answer. I won't do it... Thank god I have the 1.8T in my B6!
