Results 1 to 10 of 10
    Senior Member Two Rings dreVanHalen's Avatar
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    bypassing stock amp
    is this possible? I really dont want to have to re wire my whole car.
    Has anyone actually done it and have pics?
    Any help much appreciated seeing as I am doing my install tomorrow
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    Re: bypassing stock amp
    nobody?
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    The wiring adapter to use it won't work for you?
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    well the stock amp has 2ohms of impedance. My deck and speakers are 4 ohm therefor it needs to be removed and rewired or bypassed. It would make my life a whole lot easier if I could bypass the amp but I am having a hard time finding a wiring diagram so show which wires need to be connected in order to achieve this. Any help would be greatly appreciated.
    Jun 30 2008
    Erie, Pennsylvania
    I may be able to get you a diagram. I need to know exactly what you've got: year, avant?, quattro?, bose?, # of speakers?
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    Its is a 2000 a4 1.8t quattro bose 6 speaker system.
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    believe it or not the bose stereo in our cars uses all 4 ohm speakers. aftermarket speakers work pretty well with the stock amp, their maximum volume is just pretty limited due to the low wattage the amp puts out. I believe all newer Infinity speakers are 2 ohm, this would extract more power and volume from the stock amp.
    Its really not bad to run new speaker wires into the front doors and to the rear deck, took me a whole hour to do it right... tying the wiring in the right places and everything.
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    how much of the interior did you have to take apart? and I would need to run it to the rear doors as well. Are you positive that it would work if I just used the wiring harness that came from crutchfield and used the stock amp? I am willing to test it out if it will work to see if I am satisfied with the volume, Then possibly run new wires when I get the time to install an amp for the rear deck speakers I got.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Impedance isn't a flat line. It varies quite a bit with frequency.
    http://www.roger-russell.com/wire/wire.htm#nominal
    Jim
    I Do Werk.
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    I just bypassed the amp by running my own wires. It really doesnt take that long.
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
