Results 1 to 6 of 6
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Brake pedal is mushy
    So, I finally got all 6 lines put in and had the brakes flushed and bled. Now, the pedal feels even more mushy than before. The car stops but the pedal goes to the bottom and you can pump it a little but it does not feel like it did before I had the brakes done. Any ideas? Could something else be broken or is this what I have to deal with using hawk pads and powerslot rotors? I used Amsoil DOT 4 brake fluid.
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Re: Brake pedal is mushy
    Umm, maybe bleed the brakes one more time? I got lines on mine and I could totally tell the difference after I did it. Brakes should feel about 10-15% firmer. If it still does it then maybe check the master cyl? Best info I could tell you.
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Jan 17 2005
    New Jersey
    Yeah, after this beel it is worse than the last. We are thinking about doing it one more time. I also brought up the master cyl but other than buying brakes, I know nothing! Do you think it could be something with the fluid or not an option? It was brand new fluid that aint cheap.
    Aug 06 2008
    Canadia
    you have air in the ABS pump like i did, you have to bleed the brakes, activate the abs, bleed the brakes again, etc. it took me about 5 times to get it right, since its such a waste of fluid i flushed it out with wal mart dot 3, then when all the air was out i bled it one last time with dot 4.
    if you have vag com you should be able to run the abs pump while you bleed the brakes, thats how the dealership does it, but they charge out the nose for that.
    Feb 12 2004
    Orange County, CA
    that is good to know. Learn something new every day here
    2021 C8 RS6
    2006 S4 Avant SOLD
    Jan 17 2005
    New Jersey
    Just out of curiosity, how did you get your ABS pump to run?
    I just fixed this today. We had the car on a lift, would put the car in drive, race it to about 80 then hit the brakes to activate the ABS and bleed away. Now, the pedal feels 120% better.
