Results 1 to 4 of 4
    Senior Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    Car won't start! HELP!
    Okay, so like 20 minutes ago I leave the house to go to the store. I make it 3 blocks, come to the stop sign and stop. Leave the stop sign, get through first and second gear, shift to third and the car bogs down and dies. Now it won't start for the life of me.
    I've checked all the fuses in the dash panel on the drivers side that would relate to this, and they're fine. And I'm not sure what the problem would be.
    Any help would be great, since I'm totally clueless right now.
    (2000 A4 1.8T ATW 5spd, no engine mods)
    2006 Jetta TDI
    2000 Brilliant Black S4
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Car won't start! HELP!
    first off, will it turn over?
    Apr 27 2008
    White Plains, NY
    Quote Originally Posted by bmx_a4 View Post
    Really not enough info. in this post to say what it could be. The car stalled after leaving home. Could be the coil going bye-bye if you had a lot of misfiring going on which caused the stall. Or it could be timing belt. Really you need to check for engine codes before more can be said.
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    Not to be a smart ass, but did you run out of gas??
