Results 1 to 2 of 2
    Registered Member Two Rings
    Aug 20 2007
    2000 Audi S4, 2006 Yamaha R6
    Clermont Florida
    B5 S4 cooling system Q's
    How can i test these 3 sensors?
    black radiator fan sensor from passenger side behind the head (4 prong)
    green after run pump sensor deivers side behind the head and (2 prong)
    blue aux fan switch from lower radiator hose (4 prong)
    Neithor my primary or aux fans come on anymore aswell as my afterrun pump does not stay on long causing the car to go very slightly over the middle of the coolant temp gauge after shutdown
    fans work for sure. (tested)
    I'm trying tosee if these are the issue or if i have to move onto a fan controle module or w/e these german cars have on them
    Also
    there is supposed to be a 1 way valve in this line i highlighted and pointed out in this pic, Which way is the coolant supposed to flow though? towards the expansion tank or rear coolant line?
    Zac O.
    50th aniversery Yamaha R6
    2000 Audi S4
    Aug 06 2008
    Canadia
    Re: B5 S4 cooling system Q's
    I'd be looking at the fan controller and thermostat.
