I'm gonna go ahead and say what I think several people in here are afraid to say based on not wanting to step on any toes. Your fuel pump is to blame. Here we go:
ive done logs, ive checked for boost leaks, ive tried flashing it back to stock and then back to the file... the car feels like its getting a cut from somewhere, i did a pull late at night on a quiet road with my mechanic and we both came to the conclusion its boost related. it feels like the car spools and then just cuts, the tries to pick up pressure, the cuts, the time gap between these "cuts" is about 1 second intervals
You and your mechanic are wrong. Boost cuts (loss in boost pressure) will occur when a fuel pump cuts fuel to the engine. There's no magical mystery to boost problems, there either is a leak or it isn't. Fuel cuts cause the same feeling as boost cuts, i.e. from a boost leak. My friend's Stage II APR GTI does this. Every time he gets a fuel cut, you can watch his boost guage fall to 0. He is only Stage II, though, he doesn't have a fuel pump. There is a difference between the Stage II file and the Stage II file + Fuel Pump. The regular Stage II file is setup to cut boost when needed to prevent fuel cuts from the fuel pump. The software is not perfect, hence the reason so many people get them anyway when they drive the car hard. I have no idea what file you are running from APR, but if you are running the regular Stage II, no fuel pump file, and are having issues even though you have the Auto Tech fuel pump then do the math and it's the fuel pump causing your problem because your fuel pump, in theory, should be able to keep up with whatever the software demands and if the software isn't demanding the fuel, then your pump isn't going to supply it. Hence if the software isn't demanding more fuel from your fuel pump, why would you get cuts? The same would especially be true if you were running the Stage II + Fuel Pump file from APR with the Auto Tech pump and you're getting cuts. Again, in this case, the blame would fall on the fuel pump this time for not supplying what the softare demands. It's not APR's fault you bought a fuel pump not up to the same specification as theirs.
Yeah but the guy had his car Reflashed, with the stock Pump, not an aftermarket one...
So it should work right...
Changing the pump isnt the solution...
The car should work as it is with a right software...
Not true, if there is something wrong with the pump, it could act fucked whether there's software loaded to the ECU or not.
I haven't had any problems with mine and I'm running APR with an aftermarket fuel pump.
This is mostly likely due to the fact that, like me, you are running the
APR rebuilt fuel pump with the proper files and not the Auto Tech one. I've heard of many people having issues with theirs and MUCH less with APR's (not that APR's doesn't have a failure rate).
i really want revo, but now i have to wait until my funds are adequate.
Switching to Revo and jacking with the settings is going to further fuck you up.
