Results 1 to 3 of 3
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Quick question about stock suspension
    Is the oem sport a4 suspension lower than the stock s4 suspension? or are they the same...and am I assuming right that the s4 shocks are better?
    TIA
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    Re: Quick question about stock suspension
    your right, The s4 suspension is better, but if you put it on your a4 the nose will sit high because the springs are made to support an 8 cyl. I learnt first hand. Your best bet would be to use the s4 shocks with some aftermarket a4 springs
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    If you park a stock S4 next to a stock sport 1.8t then you'll find that the S4 is 1/4 - 1/2" taller in the front. The rears should be close to the same height.
    If you put the springs from an S4 on a 1.8t or 2.8 it will be higher than the stock S4 which is already higher than stock 1.8t sport.
    The S4 and A4 dampers are interchangeable. I ran 1.8t A4 sports, then the same springs with S4 dampers, then another set of A4 sports. These were mostly winter suspensions but also did some summer and track driving. The last set was on more than a year. If anything the S4 dampers are slightly tighter feeling but it isn't enough to worry about.
    Jim
    I Do Werk.
