Originally Posted by
Affinitive
Sorry, kinda stayed out of the tech sections lately. Been insanely busy and haven't had time for my long winded posts. I do remember seeing something a while back about swapping injectors.... and stayed out of it for, well, ... a number of reasons.....
Anywho,...only the multi trims are whacky....eh??? Yes yes yes, we all like whacky trim.....
Hello Affinitive,
Thank you so much for stepping up with some new thoughts on what could be remaining for me to check. I extremely appreciate it!
Answers to your questions:
Yes --- AHA motor
Yes---original purple top injectors in it, except presently I have installed 1 new injector bank 1, the new injector has a red top. I am contemplating returning the purple injector once I get this is fiasco resolved. I also put a new fuel pressure regulator on the rail and changed the small vacuum lines leading to it. No changes. I have not actually connected a fuel pressure guage to the rail, however.
Colors---I read that white on spark plug electrodes indicates carbon deposits, and normal coloring should be tan-brown. But of course, the plugs are only 4 months old so their proper coloration may not have set in yet. O2 sensors color I thought white meant antifreeze or silicon contamination, though I'm not sure what the normal coloration is. It was good to take them out and look at them anyway.
The O2 sensors are the originals, I had to cut the wire straps to get them out. I swapped them because I want to see if one or both are giving false high voltage readings, perhaps due to some contamination blocking their ability to see oxygen. Overall, I have been trying to make bank 2 trim more severe than bank 1 to identify the cause of this problem, but nothing I've swapped (injectors, O2 sensors) has had any effect, suggesting that these parts are not bad.
My trim numbers seem to prove to me that the computer is making the engine run lean, perhaps improperly, because it thinks that the exhaust is rich. Only multiplicative trims have been a problem, correct. Bank 1 is always more negative than Bank 2, but both do tend to creep up together and, at the extreme, Bank 2 does go out of spec. too. It does take a few days or a week or more before the DTC comes up, and there does seem to be some intermittent spikes in the readings that are partially responsible for the long learning processing.
Plastic intake duct--- I've taken this off a few times now, most recently in order to swap the O2 sensors (yes, I did remove and re-install them from under the hood, not under the car). The seal is a little bit soft rubber, and it does come off the plastic duct without much difficulty. I've never done an intake pressure test to check that, yes. The intake duct does have a little bit of oil in it from the oil venting line, I have to wipe that off each time before re-installing the duct, and I suppose that some oil does get under the seal maybe. The car also does have a small oil leak, probably through the valve cover gaskets, I've been told that this oil leak could not be the cause of my fuel trim problems.
The car does not have a turbo engine, so my understanding has been that if the intake has a leak, the result would be UNMETERED AIR (not false air), resulting in the O2 sensors and ECU seeing a TOO LEAN mixture and adding fuel to compensate (positive trim values) and possibly throwing a TOO LEAN DTC. I have the reverse situation, false air would require metered intake air to get blown out the system after the MAF, resulting in less air reaching the combustion chamber than expected. And it would affect both banks approximately equally too, wouldn't it? The only thing interesting about this thought of yours is that after my swap of the O2 sensors this weekend and re-installing the intake duct, I am now getting, for the first time, somewhat (but within spec.) lean results on additive trims on both banks, but the multiplicative remain rich and too negative on bank 1 as before.
I'm not sure what you mean by the Jet Suction Pump, do you mean the Secondary Air Injection pump? If not, what is the thing you are talking about and where is it approximately? My secondary air injection pump does seem to be blowing air up under the hood, but it still does blow air up the plastic piping correct too. Supposedly a leak there should not affect trims.
Knowing all these things, I don't understand why I haven't found the cause of this problem, but hopefully you can shed some further light on these facts to bring me closer to finding the cause. Thanks.
CP
