    Veteran Member Four Rings drlandry00's Avatar
    Dec 19 2004
    2000 A4 Quattro 1.8t 5spd Ebony...
    rhode island
    Need some Help (info)
    Hey boys,
    Its been a while since I have been on. But a friends 98 A4 1.8t is in need of some help.
    There is a grinding, fast rattling noise coming from the front passenger side of the engine compartment- so I figured it was the turbo going. However after some close inspection, I noticed that the noise would go away if you turned the a/c or defroster on. (when you engaged the compressor). So I did a few more checks and it seems like it might be the A/C compressor. Funny thing is that the a/c still works. (if you rev the car, the rattling is there, until you turn the a/c on) I dont think the turbo would do that if it was bad.
    What do ya think. I have already searched the topic and there isnt much. If you do think it is the compressor- is this the right one?
    997 - 2001 Audi ~ Volkswagen Air Conditioning : Compressor
    [MediumImageHyperLink]
    Weight: 17.0 lbs
    Manufacturer: AC Parts House
    Remanufactured Compressor
    Zexel DCW17D - 4 Groove Clutch 4.75" Diameter, 1.95" Gauge Line - 8D0-260-805D
    Part # 61416
    List Price: $335.21
    Your Price: $254.36
    Thanks boys!
    Cheers,
    Dave L.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Need some Help (info)
    It sounds like the clutch assembly is bad. I would check out the serpentine belt tensioner first though.
    For a 98 1.8T, the OEM part number 8D0-260-805D, matches what I have.
    Dec 19 2004
    rhode island
    The serpentine belt- is that the thinner belt on the lower driver side? Because that belt was fairly loose. But figured that was another problem, as that belt isnt even close to the a/c compressor and the noise.
    Also, there is a fairly big tensioner on the upper middle of the front of the engine-- i believe that is the main belt tensioner- that thing is on a funny shaped arm- and it sort of bounces around with the movement of the belt- is that right?
    Thanks for the reply..
    Cheers,
    Dave L
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    wow haven't seen you on here in a while, pretty sure i bought your k04 and exhaust from you a long time ago... the tensioner is not suppose to jump around when idling, check to make sure its on their tight.
    ::2002 S6
    Dec 19 2004
    rhode island
    Yea- its been a while- I now drive a 08 Chevy Silverado- So I am not to into the Audi's anymore.
    I will look into the tensioner-
    Is there any way I can check to see if it is the compressor that is bad?
